1953NAA-How do I check hyd pump pressure
Jim SPencer
10-03-2002 16:49:17
I would like to check the hydraulic pressure of the vane pump that was recently rebuilt.
I cannot lift over 50 lbs and suspect pump may be cause.
I have a manifold plate on top that has the letters NAA-478-B on it.
It has 2 outlets in it.
Can I somehow check pump pressure using one of these ports?
I was thinking of removing the lift cover and tapping threads in the pressure hole on the right side of the case edge but there must be another way.
Will someone please help with information?
Jim
John (OH)
10-05-2002 07:29:28
 Re: 1953NAA-How do I check hyd pump pressure in reply to Jim SPencer, 10-03-2002 16:49:17
Jim,
If you look directly down from the valve plate on the top cover, you will see a large cap nut. Below this is a pipe plug that requires a allen wrench to remove it. This is where you will need to install your hydraulic pressure meter. After doing so, chain your lift arms down, start tractor and raise the control level to the highest position. With a pistion type pump, I can obtain 3000# psi before the bypass valve takes over.
Hope this helps,
John
HERE'S YOUR PICTURE...EDDIE8N
10-03-2002 19:31:39
Jim,
Sorry it took so long, I was having trouble with my posting site.
third party image
EDDIE8N
Jim Spencer
10-03-2002 16:58:08
If anyone has any ideas I could send them a picture by Email. I have a picture on my computer of this manifold assembled to tractor.
I just don't know how to post a picture here.
[email protected]
EDDIE8N
10-03-2002 17:23:23
 Re: Re: 1953NAA-How do I check hyd pump pressure in reply to Jim Spencer, 10-03-2002 16:58:08
Jim,
E-mail the picture to me and I'll post it for you.
EDDIE8N
[email protected]
