12 volt fuse size
fred
10-03-2002 11:03:19
I just bought the light switch that also holds the fuse for my 12 volt light system on my 8N. What amps will the fuse need to be to pull the two front lights and the rear light? Thanks, fred.
PHILIP
10-03-2002 12:30:59
 Re: 12 volt fuse size in reply to fred, 10-03-2002 11:03:19
MY 2 FRONT LIGHTS (3 AMPS EACH), 1 REAR LIGHT (3 AMPS), AND 1 REAR RED LIGHT(1 AMP) PULL APPROXIMATELY 10 AMPS TOTAL. I BELIEVE I USE A 20 AMP FUSE AND #12AWG WIRE. PHILIP.
fred
10-03-2002 12:59:43
 Re: Re: 12 volt fuse size in reply to PHILIP, 10-03-2002 12:30:59
Thanks Philip, I'll get them on the way home.
Soundguy
10-03-2002 11:22:16
@ ways you can go about it. Check the wattage of all loads in the circuit, and then apply the following formula. ( P = I E )
Where P is power ( wattage ), I is current ( an unknown that you will be solving for ) and E for voltage. Don't use 12v.. use normal charge voltage. After starting your tractor, and letting it run and recharge the battery from the start, take a couple of voltage readings.. use the average of these voltages.
Yor formula will actually be ( P / E = I ) That is, total power, divided by the Voltage, equals current flow inthe circuit.
That will show you calculated current. Size your fuse from there. Choose the closest size up. You may want to use a slow-blow. Minimal extra cost.
Or, you can hook the circuit up un-fused, and check it with an ammeter. Clamp on is ok, shunt style is better.
You will probably be safe enough calculating it.
Give yourself a little headroom on the wattage number, as it is probably an assemblyline approximation.. much like a resistor ( resistors have a tolerance, denoted by a color band... the resistance can vary by the percentage indicated on the band.. some as much as 20% ).
Soundguy
fred
10-03-2002 11:38:40
 Re: Re: 12 volt fuse size in reply to Soundguy, 10-03-2002 11:22:16
WOW! OOOOOKKKKK, I'll try. Thanks.
