You may have some compelling reasons to convert to 12 volt, but I don't know your situation. If you want to run 12-volt accessories, or add an AM/FM/CD player, it may be a good idea..."IF" it is done right. Problem is that too many folks make it worse by converting.To start and run the 8N, the 6-volt system is fine, as long as it is maintained. A lot of folks have the idea that if the starter doesn't sound like the starter in their car or truck, then it's dragging. The 6-volt Ford starter has a unique sound( a sort of "grind, clunk, grind") but that doesn't mean anything is wrong with it. Many folks think that a 12-volt will start the tractor better in cold weather. But there are plenty of 6-volt N's that start readily in cold climates. If you already spent the money and it's working, leave it alone. If you find it doesn't work, change it back. As far as the painting, you can paint it yourself. You can use a brush or rattle-cans or a spray rig. If you care about details such as color and drips and runs, it can be frustrating, especially if you have never painted a vehicle before. 95% of a paint job is prep work. Throwing paint on is the fun part. Cleaning, sanding, patching, removing dents, are the hard things. It can be a very gratifying project, even if it takes a looooo ng time. It would be better to practice on an N than your wifes' new car.
