52 8N
another firing order question
soundguy
09-29-2002 13:39:20
Ok, my cow helped me out by removing the plug wires from my side mounted distributor cap.
the i&t manual states, 1243
1 is marked on the cap, and if i have doe it right, 2 is counter clockwise from 1 ( away from tractor ), etc.
If I understand it, wire 1 from the cap goes to 1st plug, up by radiator, 2 goes to second plug, 3 goes to last plug, and 4 goes to 3rd plug.
Starts that way... sounds about right I guess.
Is this correct? ( Dell? )
Phil (NJ-AZ-SK)
09-30-2002 03:48:02
 Re: 52 8N - another firing order question in reply to soundguy, 09-29-2002 13:39:20
Soundguy, The normal side mount dist can be installed such that the # 1 Cap spigot (Marked) is not aligned with # 1 cylinder. Some of the old timers just move the wires to match cylinders and rotate the Dist (quick & easy field fix). Its always best to insure that the Rotor is Pointing at Cap Spigot # 1 when cylinder #1 is at the top of its Compression Stroke.
JMHO
Y E S ! ! ! . . . Dell (WA)
09-29-2002 14:01:39
that is correct all N's (front or side mount) firing order is 1,2,4,3 CCW..... ....Dell
Hey soundguy look at the posts on this page....
09-29-2002 13:59:12
it can't get any simpler than that..... ..!!!!
soundguy
09-29-2002 17:38:27
 Re: Re: 52 8N - another firing order question in reply to Hey soundguy look at the posts on this page...., 09-29-2002 13:59:12
I figured I had it right, I just wanted to make sure that I was identifying #2 correctly... however since it started, I was pretty sure it was correct.
I read the other posts, but the info on the cap I was looking for was different, as the one in the previous discussion was for frontmount.
thanks, ( and thanks Dell )
soundguy
