12 volt or 6 volt that is the question
Mark Duensing
09-20-2002 20:01:04
I have just purchased my first 8N and have been doing a bit of research. The tractor has had some what of a 12 volt conversion. The alt/generator is missing and there is a resister on the ignition circuit. A 12 volt Battery that is hooked up neg ground. Now from my research best I can tell the tractor came out 6 volt positive ground. I am confused please someone straighten me out here. Should I go back 6 volt or try and finish the 12 volt conversion? Last question I need to get a shop/service manaul can anyone give me a suggestion?
Jim WI
09-23-2002 10:39:42
 Re: 12 volt or 6 volt that is the question in reply to Mark Duensing, 09-20-2002 20:01:04
Unless you've already got the 6V generator (or can get one real cheap), it would be cheaper to finish the 12V conversion. The hardest part is coming up with the mounting brackets.
'Course, if you get bitten by the restoration bug, you'll be buying the 6V parts anyway so that it is true to the original design. ;^)
Mark Duensing
09-21-2002 21:57:26
Just a side note I started the thing tonight after it had set for 5 years. A little Marvel mystery oil in the cylinders overnight and a fresh oil change and a starter selenoid. Dynamite $600.00 buck and it runs.
Dave Smith
09-21-2002 13:43:06
Mark, Go to the link below for wire diagrams.
Dave <*)))><
Wayne Mo
09-20-2002 21:01:53
I would definitely go back to 6v pos ground. I think the main reason people change them over to 12v is either troubles in starting or cheaper to get a junkyard alternator than rebuild a 6v generator. Neither of these reasons are valid in my book! If it won't start on 6v you should fix the problem instead of juicing up the starter circuit. Using a cheap junkyard alternator is short term thinking too. 6v batteries are cheaper and are not so hard on your starter and flywheel ring gear. Of course the looks and originality dictate 6v.
Dave OH
09-20-2002 20:38:32
The I&T FO-4 manual is most used by people on this board. Check left side of screen and I am sure they have them for sale. 6v vs 12v: You first have to determine what you have. A 6v system is pos. ground. a 12v system is neg. ground.
Look in the archives for a 12v system wiring diagram, this may help you decide what you want to do as it should show you if the wiring is set up right. There should also be information about the type alternator you need if 12v is your goal.
What did the seller tell you about the missing alternator?
Dave OH
Mark Duensing
09-20-2002 20:43:56
 Re: Re: 12 volt or 6 volt that is the question in reply to Dave OH, 09-20-2002 20:38:32
I have not call him about the alt. yet I am sure if he has it he will let me know.
Dave OH
09-20-2002 20:52:11
 Re: Re: Re: 12 volt or 6 volt that is the question in reply to Mark Duensing, 09-20-2002 20:43:56
Also ask him if he knows what ignition system is in it and if it is finished.
Dave OH
soundguy
09-20-2002 20:32:51
These tractors came out originally 6v pos. grnd ( as you knew ).. and have worked fine like that. Some have chosen to convert to 12v neg grnd for an alternator, or even 12v pos. grnd using a rebuilt generator.
More or less up to you. Do you want to keep it original or stock?
I havn't checked prices.. but I'll guess it is pretty cheap to get a 1 wire gm alternator... probably cheape rthan a generator, but you never know.
I chose to keep min 6v... I'm not bothered by the slower sounding starter, and my headlights are plenty fine.
Do a price comparison on the rest of the conversion vs. going back to 6v.... you're almost in the middle, depending on the condition of the battery.
Might check to see if the starter was replaced with a 12v starter.. that will effect the decision.. most though just keep the 6v starter and change the relay.
What year is your 8n? Does it have a front or side mount ignition?
Later,
Soundguy
Mark Duensing
09-20-2002 20:58:49
 Re: Re: 12 volt or 6 volt that is the question in reply to soundguy, 09-20-2002 20:32:51
The battery is shot the tractor has not been started in 4 years and I am sure I will end up doing a overhaul this winter but I would like to see if I can get it to fire off and run before I start to tear it down. This is my first tractor but I am not foreign to the tool box. I have worked on cars for years. This tractor though Has made me excited to get started. Something new to learn.
The tractor is a 1949 with the front ignition.
Thank for your reply and any help will be greatly appreciated.
Dell (WA)
09-20-2002 21:42:10
 Re: Re: Re: 12 volt or 6 volt that is the question in reply to Mark Duensing, 09-20-2002 20:58:49
Mark..... ....Electrically, the 8N is just about as basic as they come. The frontmount ignition system does take some getting used to. Like to change the points, 2-bolts to remove the distributor and change the points on your workbench. The dist drive is offset and can only fit oneway. I&T FO-4 has great pictures better'n words.
As for converting to 12 volts. I'm a 12 volt advocate for the right reasons.
Use the 6 volt starter, it don't care, positive or negative ground, still turns the right way. Use 6 volt starter solenoid, not a problem on 12 volts.
Ignition points and condenser, don't care 12 volt ok. Ammeter only semi-cares, may have to exchange wires to get ammeter to show charge (+). Lights do care, 12 volts mak'em flash dark.
12 volt alternator CARES, negative ground only.
Ignition coil cares. If you decide to use the OEM 6 volt frontmount coil, you MUST use both the "infamous ballast resistor, mounted on the backside of your dashpanel AND a 12 to 6 volt converting resistor. Wire them in series like flashlight batterys.
If you decide to use the new 12 volt frontmount coil, (which I advocate) DO NOT USE the ballast resistor. understand??? BUT you still need a current limiting resistor to keep your coil from burning out.
This is really tricky. Get a 2-pack of 1 ohm 10 watt resistors from Radio Shack. Twist and solder the resistor leads together in parallel. You now have about 1/2 ohm current limiting resistor to keep the 14.7 volts of alternator output from melting your 12 volt coil. (yeah I know, lousy designers)
Now for the Delco SI-10 alternator, (most commonly used and cheap) you have to decide wheather to use the 1-wire version that takes about 2000 rpms to start charging or the 3-wire version that starts charging at 450 rpms. I personally don't like to jazz a cold engine to get it started charging.
I know of 6 different ways to wire a 3-wire alternator scheme. General Motors uses the idiot light scheme to excite the alternator P-1 from the igntion switch. And P-2 sense gets a short loop of wire from alternator BATT terminal. BATT is usually wired to the BIG battery terminal of the starter solenoid.
If you don't isolate P-1, the built-in voltage regulator backfeeds power to the same "ON" terminal that the ignition coil is fed from and you will NOT be able to turn your engine off without some sort of isolation, idiot light (use a trailer marker light), 10 ohm 10 watt resistor, 1N4001 diode, DPST ignition switch, pushbutton doorbell switch.
Your call, but do it right and be proud of it..... .....Dell
Mark Duensing
09-21-2002 20:39:26
 Re: Re: Re: Re: 12 volt or 6 volt that is the question in reply to Dell (WA), 09-20-2002 21:42:10
Dell does it matter which resister comes first The 12 to 6 volt or the Ballast resister. Last question for now, is that what I ask for is a 12 to 6 volt resister or does it have a fancy name.
Dell (WA)
09-22-2002 00:26:31
 Re: Re: Re: Re: Re: 12 volt or 6 volt that is the question in reply to Mark Duensing, 09-21-2002 20:39:26
Mark..... ..... .Ford lists the 12 to 6 volt converting resistor as p/n "8NE 10306". NAPA also sell 'em but I don't remember their p/n for certain, I think "IU-100" or "IR-100". This 12 to 6 volt converting resistor is not normally a Radio Shack part, and they wouldn't know it by that name anyways. But because I'm an electronics engineer, I'd buy a 3 ohm 25 watt ceramic resistor from Radio Shack and it would work for me. Just remember that the converting resistor gets very hot and must be mounted securely aways from anything plastic (like wiring harnesses).
Resistors, like flashlight batterys, don't care who is first, just as long as the 6 volt frontmount ignition coil is last in line..... ...Dell
Dave OH
09-21-2002 22:53:19
At Radio Shack? Don't confuse them, they already are.
Just ask for the resistors that Dell recomended.
That is how they are listed in the Radio Shack catalog.
Dave OH
Ford-man
10-15-2003 22:25:42
 Re: Re: Re: Re: Re: Re: 12 volt or 6 volt that is in reply to Dave OH, 09-21-2002 22:53:19
When using the 1-wire hook up on the Alternator (charging at 2000 RPM) what happens to the other wires in the harness? I notice they go back to the old Voltage regulator. Is the old external voltage regulator completely eliminated when converting to 12V this way (using the volt regulator inside Alt)?
Ford-man
soundguy
09-20-2002 21:02:41
Since it is a front mount, and you see an extra resistor, ( there is also one unde rthe dash, a 3 terminal job. Most 12 conversions use both the resistors. Sounds like you still hav ethe stock coil setup, etc. ( Though I have seen electronic ignition setups for both the front and side mount units.
If it were me, I would go back to 6...but then, you may want 12 to run common automotive appliances with it, etc. Just depends on your wishes, and the price of the two options.
Soundguy
