Order Ford 8N Parts Online
8N cylinder bore specs.
Joe
09-20-2002 16:12:41
Please assist. My Dad's 8N is apart. What should the cylinder bore diameter be? Pistons have a .030 stamped on the tops. Engine had low compression and was blowing alot of smoke prior to dis-assembly. Need to know the above and what the typical ring gap should be. Pistons have 3 rings on them.
thanks
Joe
Ed Gooding (VA)
09-21-2002 03:39:12
 Re: 8N cylinder bore specs. in reply to Joe, 09-20-2002 16:12:41
Hi Joe. Here's some additional info that may be of use:
Third Party Image
Hope this helps..... ..... Ed
'52 8N475798
JimNC
09-20-2002 16:58:46
Bore is 3 3/16" Ring gap is .010"-.017"
