Installing PTO on 4000 Ford Tractor with 8 speed transmission
Gary L. Witt
09-19-2002 06:49:39
I'm having problems with re-installing PTO on 4000 Ford Tractor with 8 speed transmission after replacing the snap ring.
The PTO shaft is not bent or sheared.
Any suggestions?
Scott
09-19-2002 09:49:16
 Re: installing PTO on 4000 Ford Tractor with 8 speed transmission in reply to Gary L. Witt, 09-19-2002 06:49:39
There is a washer that can fall out of place in the pto drive, look up and if it can be put back in place smear vasiline on it and use a long small rod to get it back in place, if not the tractor must be split between the trans. and rear, the snap ring may have broke because the pto on your attachment does not slide in and out easy.
