Order Ford 8N Parts Online
48 8N problems
Jim-IL
09-17-2002 10:14:56
I started the tractor this morning and it popped off fine and ran like a charm, then I shut it off and had a hard time restarting. When it finally started it ran terrible, backfiring loudly and having no power whatsoever. I had recently overhauled the carb and the governor, and replaced points, condensor and coil. The plugs were new 6 months ago. The tractor had been running good except for a slight miss. Also when I restarted this morning a mouse crawled out on the transmission cover. I don't know what he could have done. I bypassed the ignition switch to see if that was the problem to no avail.
Fast Ed Ohio
09-17-2002 23:07:01
 Re: 48 8N problems in reply to Jim-IL, 09-17-2002 10:14:56
I had a mouse build a nest in the carb. intake tube, 8n would start but had no power .
Dave OH
09-17-2002 16:57:40
The advise you received is good. My guess, if there are no chewed wires would be a stuck exhaust valve. This is not rare.
Dave OH
Evil Steve
09-17-2002 12:03:05
ALWAYS check your tune-up first when you have an engine miss/poor peroformance. Takes only a few minutes and you have to rule tune-up problems out first before starting elsewhere. Points slip on these tractors often and it'll do it between one start and the next.
I wonder whether your dist is worn. It'll cause that sporatic miss and slipped points. Pull the rotor off and move the dist shaft side to side and check for play. Shouldn't be any. Only 1/8" up and down play. After tune-up check, pull plugs and observe spark. Should be whiteish/blue. If not, one of your ignition components is failing or shorting.
If tune-up doesn't fix, realize that poor carburation/governor do NOT cause AFTERfire. "Backfire" is thru CARB and wouldn't be loud. Afterfire can only be caused by pre-ignition (poor gas or timing incorrect or dist shaft worn or incorrect firing order or burned/stck exhaust valve).
Definately check for chewed wires as Rusty suggests although it's hard to believe that it ran fine earlier in the day and now it isn't due to chewing in that time gap.
If none of above works, make sure gas filters are clean. If clean, shoot some starter fluid in each cyl and see if it fires up better - will indicate fuel supply problem.
if all of above is okay, time for a dry and wetcompression test.
Rustyt 2N
09-17-2002 10:30:06
Look at your wiring & see if that mouse was chewing on them. Mice can get into places you wouldn't believe.
Fast Ed Ohio
09-17-2002 23:04:09
 Re: Re: 48 8N problems in reply to Rustyt 2N, 09-17-2002 10:30:06
I had a mouse build a nest in the carb. intake tube, 8n would start but had no power.
Fast Ed Ohio
09-17-2002 23:03:28
Jim-IL
09-18-2002 15:29:45
 Re: Re: Re: 48 8N problems in reply to Fast Ed Ohio, 09-17-2002 23:03:28
Went back to the tractor and tried bypassing the ignition switch again and the tractor started up and ran like a charm. Thanks for your help.
