2N Tractor Sputters under load changes
Cliff (VA)
09-14-2002 23:28:28
My father-in-laws 2N sputters and almost dies under load changes (going up hill or bushhogging in heavy grass). Otherwise the tractor seems to run well. Is this a problem with the governor? Can I take it apart and clean it or should I overhaul?
Thanks in advance
Dave OH
09-15-2002 17:22:23
 Re: 2N Tractor Sputters under load changes in reply to Cliff (VA), 09-14-2002 23:28:28
I had a similar problem when I first purchased my 8N. I found that by pulling out the choke when it was stalling under a load made it run. Found problem to be dirty filter screens, not enough gas when govenor opened. Simple enough to try.
Dave OH
Rusty
09-15-2002 11:46:43
Look to the ignition system. You can see if the govoner is functioning. Just put the tractor under load and it should open the throtle.
Ron/PA
09-15-2002 04:56:10
When ever I find this, I always suspect spark first, plugs and wires, then cap and rotor. If it's been a while or you don't have good solid wires I'd try that
Ron
