Jubilee ford
kim
09-09-2002 09:15:15
I have a chance to buy a 1953 jubilee and am wondering what it is worth in U.S. dollars and if its better to paint it up or just leave it in the condition I found it
Thaks
Kim
Craig
09-09-2002 18:50:11
 Re: jubilee ford in reply to kim, 09-09-2002 09:15:15
If it runs good with no smoke.The tires are abought 50% worn ,The hydraulics work good (at least will hold your body weight while standing on them with the tractor shut off),And the sheetmetal is fairly sraight with no serious rust through I, d say its worth near $2000. Good luck, Craig.
Robert
09-09-2002 16:01:13
third party image
The condition really does make a difference. Here's one that is a good example of the low end.
Gaspump
09-09-2002 18:03:28
 Re: Re: jubilee ford in reply to Robert, 09-09-2002 16:01:13
I dunno, The 8N I am nearing completion of fixing up looked a lot worse than that when I started, only mine had two front tires, car tires so out of round that the front end would jump off the ground when the former owner towed it to my place. It is a long story why I fixed it up, but in short not enough good parts to salvage from it! I see hope in that picture, may even have a salvagable hood! Good rears, engines there, Hmmm how much did you say?
Phil (VA)
09-09-2002 12:01:04
Based on the info you have given it probably is worth between $250 and $4250. Hope that helps.
