Order Ford 8N Parts Online
Loader from an 800 on an 8N?
kevin
09-08-2002 21:47:54
Would such a thing work with the pump in the 8N- or is it too puny? I have a lead on such a loader which doesn't look like a jungle-gym, but has no pump for the front, and I'd have to make or find a front mount bracket.
thanks for reading
-kb
kevin
09-10-2002 10:06:07
 Re: Loader from an 800 on an 8N? in reply to kevin, 09-08-2002 21:47:54
Thanks for the info. I guess I'll just have to go look/measure for myself to determine how much work is involved.
-kb
Jim.UT
09-09-2002 13:23:05
Dell is correct. I had a loader that came with my 800. I decided not to install it. Someone here wanted to buy it, but after swapping measurments via email we both decided it was too long for his N. Mine was a Wagner pipe frame loader, aka, climb-over style.
maybe . . . Dell (WA)
09-08-2002 23:42:42
Kevin..... .....800 wheelbase is longer than 8N's. Depending upon the mounting brackets, the 800's loader maybe too long. And YES, you will need and want a frontmount hydraulic pump set-up..... ..Dell
Fast Ed Ohio
09-08-2002 22:22:56
As far as I know, the answer is yes, I had a 601 with a front loader and it looked like every thing would fit a 9 2 or 8N , them puppys stear hard and the front ends just dont like the added weight . ( I would go with something with power steering ) .
