TimK
12-08-2000 15:03:34
Re: 2N Hydraulics still not working in reply to Mitch, 12-08-2000 05:11:18
When you had the pump out, you probably should have at least replaced the 2 pump side gaskets. The reason that I ask is that as I recall from your earlier posts, you had replaced your hydraulic oil with #134. That oil is lighter than what the tractor maybe already had in it, and the lighter oil will leak past errant cracks and openings in the gaskets faster than the 80-90 wt. In your situation right now, you can't seem to find the problem and you seem to be looking for the one thing that is causing the problem. Maybe it's not just one thing. I can't recall if you had also pulled the lift cover last time, but if you did not, the gaskets on it as well as those on the ram cylinder could be leaking now with that lighter oil. You have a problem apparently that is difficult to diagnose which I think is going to require you to pull the lift cover and, if you don't see the problem right then, replace the gaskets and the ram cylinder rings. In short bring it back to standard. Then pull the pump again (boy, I hate to advise that) and replace the side gaskets and relief valve if you haven't already. When the side plates are off of the pump, you can check the pump pistons to see if they seem to be in good working order. Make sure that the chamber in the pump that goes thru the bottom of the pump housing and feeds the line to the lift cover is not clogged. When the lift cover and the pump is out, check to make sure that the line that carries the hydraulic oil from the pump to the lift cover is not plugged. Finally, and others on this Board may disagree, but this helped my lift and that is get rid of the #134 oil and go to the heavier 85-90 wt. api service grade 1. Shell Dentax has this spec. I'm sure that smarter mechanics on this Board will disagree with me in that I'm more or less advising a total rebuild of the system, but I'm not sure of any other plan that would be better. At least you will have eliminated a bunch of variables, and I think by rebuilding the system, you will find the problem if in fact it is just one problem. My $ .02
