Order Ford 9N Parts Online
9n Broken pinion
Bob - MI
09-02-2002 19:24:57
Yes, popping the clutch while pulling the stump was stupid. I split the tractor and found a broken coupler with the end of the pinion gear in it. Should I replace the ring gear as well (matched set)? Any ideas on parts where-abouts?
Armin - TX
09-03-2002 10:44:43
 Re: 9n Broken pinion in reply to Bob - MI, 09-02-2002 19:24:57
I know that in automotive applications, the ring and pinion backlash is set on the low side or near zero for high impact type loads. I don't know what the Ford manual specs for the ring and pinion on a 9N. If the gearset had excessive wear (backlash), the impact of stump pulling may have caused the failure.
Bob
09-03-2002 18:34:35
 Re: Re: 9n Broken pinion in reply to Armin - TX, 09-03-2002 10:44:43
Thanks for the response. One thing's for sure, when I get this back together I'll think twice about pulling stumps.
ZANE
09-03-2002 03:53:21
It is always best to replace the ring gear and pinion as a matched set because of sometimes minor differences in the machining process. I would think that the difference might be in the machining of the bearing surfaces etc more so than the actual matching of the gears because I have watched my friend making gears in his machine shop and if he has a dozen to make he never changes the set up of the machine from one to the next and they are made to go with other gears that are made up on a different set up. Each gear is made to fit any of the other gears that they ride against so I think the righ gears and pinions were made in the same way. Where the difference probably would come in is the shimming of the bearings for the proper meshing of the gears.
I am working on an 8N right now that makes a whinning noise in every gear and I am sure it is from the ring gear and pinion not meshing properly. I will go in and make sure the carrier bearings are OK and if they are I'll just have to live with it because it's not bad enough for me to break the tractor to try to move the pinion bearing shims to make it just right.
Bob - MI
09-03-2002 06:28:16
 Re: Re: 9n Broken pinion in reply to ZANE, 09-03-2002 03:53:21
Thanks for the response Zane. I worked in a machine shop for many years and I know that the manufacturing tolerances allowed in gears will cause different load patterns along the tooth forms. The goal is to have constant mesh along each tooth form all around the ring/pinion. This is great with new gears readily available.
I guess that with all this said I'm in denial over this and deep down I know I should replace the set. This is a little more involved than I though it might be and I'm ticked off at myself.
I did notice however that the crack path on the broken piece of the pinion is very well defined and appears to have propogated from a notch in the lower form of the spline. Do you think Ford has a warranty on these?
Chuck A
09-02-2002 19:44:19
Check EBAY. There was one (Set)on there.
hey Dave #1 . . .
09-02-2002 19:35:50
this'uns for you..... ..Dell
dave#1
09-02-2002 20:02:43
 Re: Re: 9n Broken pinion in reply to hey Dave #1 . . . , 09-02-2002 19:35:50
Uh-Er..... .. Don't think I have any buttons on this subject but would guess that one would/should always R&R with a matched ring and pinion set, I know it's a must with an automotive ring and pinion but not sure about tractors.
Zane would be the one to ask.
Besides I'm sure our resident N series tractor hunter Mark H might have a used set for sale?
later,dave
Willy-N
09-03-2002 08:01:31
 Re: Re: Re: 9n Broken pinion in reply to dave#1, 09-02-2002 20:02:43
Sold 5 sets so far but plum out of them right now. Never could understand how you could break a rear end in a tractor they are a pretty strong set of gears to sheer off the teeth off! 90lbs of steel in the set! Mark H.
Bob - MI
09-03-2002 13:20:49
 Re: Re: Re: Re: 9n Broken pinion in reply to Willy-N, 09-03-2002 08:01:31
I was surprised too when I looked at the broken part. The end of the pinion is sheared almost straight off at the end of the coupler. Coupler is twisted and broken like a tube of biscuits. I have a new appreciation of how much torque these things generate when the tires really get a bite.
Willy-N
09-03-2002 17:03:08
 Re: Re: Re: Re: Re: 9n Broken pinion in reply to Bob - MI, 09-03-2002 13:20:49
If you have a problem finding another one get ahold of me. Thanks, Mark H.
