641 troubles
Tom(TX)
09-02-2002 11:50:17
Hope everyone is havin a great Labor Day!! Mine would be better if I could get some bushoggin done 'round the place...that bahia grass is getting high!! ...Bout' a week ago I had problems with my 641 not being able to run well under a load. It would jerk and nearly stall out while bushoggin "light" grass. I checked fuel flow and discovered a clogged filter..I replaced that and it ran fine. Today I go out to bushogg and it has hardly any power whatsoever and is jerking and stalling while bushoggin. The jerking and stallin eases up when the clutch is engaged. The throttle doesn't increase the power as much as it used to...it barely made any difference today.An hour after it began acting up..the starter wouldn't hardly engage the engine. I replaced the starter drive bout' 6 months ago and its worked fine ever since. My battery was fully charged and it wouldn't even turn over. After about 5 min w/ the jumper cables the starter began to struggle and fight to turn the engine over...it was very weak..but it cranked. Where do ya'll think the problem lies? Is it the points? Any help ya'll can give will be greatly appreciated...
Tom
bg
09-02-2002 12:14:01
 Re: 641 troubles in reply to Tom(TX), 09-02-2002 11:50:17
I'd start with cables and connections, but it sounds like you may have a tired starter. You may also have silt or rust in the gas tank that's clogging the filters. Points and condensor may need replacing, but you need to eliminate one thing at a time.
Tom(TX)
09-02-2002 12:35:38
 Re: Re: 641 troubles in reply to bg, 09-02-2002 12:14:01
Thanks bg...I just got back from checkin the lines and elbows again. I believe that I may have disloged some rust on the top of the tank...b/c this problem never occured till I topped it off one day...I had never topped it off before...so I might have some rust particles floatin around in there... Thanks for the reply...
Tom
Bill W.
09-02-2002 15:47:37
 Re: Re: Re: 641 troubles in reply to Tom(TX), 09-02-2002 12:35:38
Put you a $l.50 in line fuel filter between gas tank and carb and you will be amazed at how this will solve your trash problem. Also put carb kit in and clean out all little orfices and holes with piece of wire from wire brush. Blow out good with air compressor. Sounds like you have fuel flow problem along with a tired starter. Good tractoring....
