Key will not shut off engine.
Kenneth
09-01-2002 18:43:51
I just finnished installing a one wire altanator on my 52 8n. Also a 12 volt coil with built in resistor. I am pretty sure I have it wired correct. Went with the one wire so I would not have to have a diode or light in line to stop feedback. Now the switch will not shut the motor off only shut down the amp gauge. If I remove the wire to the alt. and run the motor off the battery the switch will kill the motor when turned off. Is the diode in the alt bad or what. This is a rebuilt alt from the parts store. Thanks,Ken
Bill(NC)
09-02-2002 05:35:24
 Re: Key will not shut off engine. in reply to Kenneth, 09-01-2002 18:43:51
I started using a switch with ACC position, and feel much better about it.
Mountainman
09-01-2002 23:39:36
After you follow Dell's advise, Do like raytasch said and add the diode or light. You'll be glad you did. Not much work.
Mountainman...CA
Dell (WA)
09-01-2002 21:15:52
Kenneth..... ...hate to rain on your parade but you DON'T have your 1-wire 12 volt conversion wired correctly. You're wired to the wrong side of your ignition switch somehow. Big clue, ammeter goes to zero and motor still runs. But since I flunked mindreading, I don't know how you wired your ignition switch, but its wrong..... .....Dell
DON TX
09-01-2002 19:14:50
I'd take it to a different shop and have them test the alt. My 1 wire 12v shuts off with the key. I have to rev it to exite but thats not a problem. My 6v does the same. Ya rev it to drive it and everything works great.HTH
DON TX
raytasch
09-01-2002 18:57:42
Put the diode, light or resister in there.
ray
