3 Point hitch won't lift
Tom
09-01-2002 18:42:39
I have an 8N (or so i've been told) and the three point hitch worked the last time I used it (3 months ago) but doesn't even atempt to lift now.Checked the hydraulic fluid and it is about an inch above full with the arms down. When I push the control arm all the way down and let go it springs back up about half way(was told it shouldn't do this). This is my first experience with a ford so any info is appreciated....
Mountainman
09-01-2002 23:31:47
 Re: 3 Point hitch won't lift in reply to Tom, 09-01-2002 18:42:39
What does the hyd fluid look like? Is it milky? Or clear? With that much over full it might have gotten water in the system. One likely source of water is the gear shift boot - less than $5. And change the fluid. Ford says use 134d.
Mountainman...CA
Dell (WA)
09-01-2002 22:35:35
Tom..... ...You do realize that the hydraulics are powered by the PTO lever by you left heel, don't you? No PTO, no hydraulics.
And you do realize your 8N's hydraulics are power and gravity down, don't you? You can lift arms by hand all the way up..... ..... Dell
