Long post
Order Ford 8N Parts Online
short question - 8N dies - cooks battery
Harry TX
09-01-2002 11:17:21
I don't know if I have multiple problems or if they're all related.
Subject: 1951 8N, 12V Conversion, 6V Coil.
Symptoms: (1) If I don't disconnect the ground cable from the battery after every use, battery goes stone dead after a couple of days. Is this normal?
(2) Tractor runs good for about 3 hours then dies. Its acts like it's fuel related, but everything checks out OK. Not flooded, good flow, clean fuel. Will restart after a few minutes - but quickly dies again. Wait a day and it's good for 3 more hours.
(3) The battery is boiling over. Ampmeter constantly shows +20 when running. Battery starts leaking acid within a few minutes.
What I've tried so far:
1) Self Regulating Alternater couldn't be checked at local parts store, because it needs to be "excited" to charge. Drove 30 miles to a "Starter Shop", where they told me it was OK, but I'm still skeptical and afraid to put a new battery in at this point.
2) Took the battery to a local garage where they tested it for a short. It's OK although on the low end of "GOOD" (It's been "cooked" three or four times).
Whats next:
I'll be checking the wiring today for shorts. Is it time for a new coil? If so, 6V or 12V?
Any help will be greatly appreciated.
Harry
Phil (NJ-AZ-SK)
09-01-2002 13:02:00
 Re: Long post - short question - 8N dies - cooks battery in reply to Harry TX , 09-01-2002 11:17:21
Harry, Sounds like you have several problems....
A.) The Alt P2 connection MUST be connected via a Jumper to the Alt BAT (output) connector. This is the voltage Sense required for regulation.
B.) The Alt P1 connection (excite) should be connected, via a diode, to the switched side of the ignition switch. When the Key is off there is no voltage to the Alt excite
I would get your Alt working first and then see what part of the ignition (coil etc) is damaged.
Hope this Helps,
Harry TX - Color me Stupid
09-01-2002 14:54:03
 Re: Re: Long post - short question - 8N dies - cooks battery in reply to Phil (NJ-AZ-SK), 09-01-2002 13:02:00
Phil,
Based on the similarity of Dell's and your comments, it's obvious that you guys know what your talking about and I don't. I've printed the replies, gone through the books, and am still drawing a blank on the P1 and P2 connections - What the heck are they? Please read my reply to Mountainman and see if we're talking about the same kind of alternator.
Harry
Phil (NJ-AZ-SK)
09-01-2002 17:04:44
 Re: Re: Re: Long post - short question - 8N dies - cooks battery in reply to Harry TX - Color me Stupid, 09-01-2002 14:54:03
Harry, >>>> All four wires BAT GRD L and F run to a small self regulator mounted on the alt, so it appears to be totally self contained. <<<<
You have an "external" regulator.... The 10-S1 that most use in 12v Conversions has an internal regulator and the P1,P2 connections.
I would replace your External Regulator
Sorry for confusion.
Mountainman
09-01-2002 12:18:20
You should not have to disconnect the battery.
When tractor dies after 3 hours run time - immediately try opening the gas cap (be careful not to get gas on the hot motor etc) If you relieve a vaccuum in the tank that could be your run time problem. Get a properly vented gas cap.
"Self Regulating Alternater" - is this the typical GM 3 wire alt? If so, it sounds like it's 'self regulating' system is faulty. Depending upon battery condition, the amp guage should show a fairly high reading after starting, and that should steadily decline until it reaches almost zero.
If your three hour run time problem isn't solved by solving the alt output problem you might try the usual suspects like key switch and coil. Also with a 12 volt conversion you want to make sure you have the right resistance in line to the 6 volt coil. If you replace the coil, I'd get a 12 volt from Don b. You will then need a different resistor to the coil.
Hope this helps as a starting point.
Mountainman...CA
Harry TX
09-01-2002 14:23:16
 Re: Re: Long post - short question - 8N dies - cooks battery in reply to Mountainman, 09-01-2002 12:18:20
Dear Mountainman,
My gascap is vented, and on failure, I can disconnect the fuel line at the carb and still have good fuel flow.
The alt looks to be from a standard "8N-12V Kit" as the alt base and adjusting brackets still have paper 8N stickers on them. The alt is marked "DELCO REM" or "DELCO REMY". There are 2 terminals - BAT and GRD and a 2-wire plug plugged into a socket labeled "L F". All four wires BAT GRD L and F run to a small self regulator mounted on the alt, so it appears to be totally self contained. Of course a wire runs from the BAT terminal to the battery via the ampmeter.
I can't tell if the wiring harnass is home-made or just ancient, but on unwrapping some of the electrical tape just at the alt, I found 2 cut wires (from the old 6V generator I assume). I may call DonB on Tuesday to see if this is one of his kits and if it's installed correctly.
Thanks for your help,
Harry
ah-ha . . . Dell (WA)
09-01-2002 16:09:29
 Re: Re: Re: Long post - short question - 8N dies - cooks battery in reply to Harry TX, 09-01-2002 14:23:16
Harry..... ....I think what you are describing is a 1-wire conversion kit to the popular 3-wire Delco-Remy 1O-S1 (or SI-10?) 12 volt alternator commonally used in most 12 volt tractor conversions. (and a lot of others) The 2-terminal plug is plugged to what we are refering as P-1 and P-2.
I haven't any real hard knowledge about your external block of "sumptin". I have heard of a 1-wire kit that makes the alternator output at the low rpms typical of tractor engines. Have also heard of the low rpms charge kit refered to as a marine kit. But I don't know for certain.
I do know that there is a 2-terminal plug wire pigtail available that you can use instead of individual blade type connectors.
I really don't know what "L" or "F" mean. L for light, as idiot light? or is it a badly printed 1??? F as a badly printed B for battery? or badly printed S for sense? or badly printed 2???..... gack..... ..
Bottom line, from your descriptions: boiling battery is caused by overcharging. Overcharging is caused by bad voltage regulator. Replace your alternator with a good Delco SI-10, they're cheap which is one reason they are popular.
From your descriptions: 3 hours of running and then quiting and overnight "miracle cure" is symtomatic of a bad ignition coil that you cannot test except by replacement.
HTH..... ...Dell
Harry TX
09-01-2002 16:47:14
 Re: Re: Re: Re: Long post - short question - 8N dies - cooks battery in reply to ah-ha . . . Dell (WA), 09-01-2002 16:09:29
Thanks Dell - I got it that time!!
Harry
David
09-01-2002 12:42:07
I have a similiar problem. After I converted to the 12v system, My battery got cooked after 6 months.. (dead as a doornail) last week.
It used to be I had to excite the alternator by getting high rpms and then the Ammeter would should charging. Soon after the conversion this stopped working and the batt started to boil.
I used to short the two spade connectors off alternator and it would work alright, now nothin.
Dell (WA)
09-01-2002 13:58:48
 Re: Re: Re: Long post - short question - 8N dies - cooks battery in reply to David, 09-01-2002 12:42:07
David..... ...if you've got a problem, don't hide it in somebodys answer, be brave and ask about it up front like everyone else.
You wrote..... ."It used to be I had to excite the alternator by getting high rpms and then the Ammeter would should charging. Soon after the conversion this stopped working and the batt started to boil.
I used to short the two spade connectors off alternator and it would work alright, now nothin"
YOU HAVE KILLED YOUR BUILT IN TRANSISTORIZED VOLTAGE REGULATOR BY STUPIDITY. AND PROBABLY YOUR BATTERY TOO.
Once you get your 12 volt alternator's built-in V/R fixed, here is what you do.
1) connect your "P-2" voltage sense blade terminal by a short wire to the alternator's battery output stud.
2) connect your "P-1" excite blade terminal thru an "idiot light" scheme using a clearance lamp to your ignition switch on terminal.
3) connect your alternator's battery charge output stud to your battery positive terminal, usually the big battery stud on the starter solenoid.
Respectfully..... .....Dell
Bo
09-03-2002 08:49:19
 Re: Re: Re: Re: Long post - short question - 8N dies - cooks battery in reply to Dell (WA), 09-01-2002 13:58:48
OUCH !!! Probably true, but that's a brutal response.
