Order Ford 8N Parts Online
8N hydraulic question
Jeffrey Phoenix
08-30-2002 19:43:33
The hydraulics on my 48 8N were working OK then they stopped working all together. I removed the plug from the hydraulic pump (bottom plate) and a little oil came out. The lift went up after I replaced the plug but wouldn't come down (well it eventually did after about an hour). Any ideas as to what the problem is? Any help is greatly appreciated. Thank you JCP
Jeffrey
08-31-2002 19:19:53
 Re: 8N hydraulic question in reply to Jeffrey Phoenix, 08-30-2002 19:43:33
Update.
The hydraulic lift was coming up even when the lever was in the down position. I picked up an 8 ft york rake and while using it had to wait a while for the rake to fall after disengaging the PTO. After a few times my hydraulics started working again. They will not stay up when I shut off the engine but at least they are working somewhat like they should. Any ideas what would cause what I am experiencing?
Thank you.
JCP
Steve IA
08-31-2002 03:31:32
Your problem description is sketchy as will be my answer. If you don't have one, get an I&T F-04 manual. Next, drain the hydraulic/transmission oil (3 drains, 1 fill) and replace with about 5 gallons of M2C-134D oil available from farm and home stores, FNH dealer or even Wally-world. Old,water-logged, dirty fluid can cause lots of problems. If, when draining the fluid, you see water, or if the fluid is milky (water in suspension) look at your shifter boot. If not in good shape, rain will find it's way into your fluid. R/R as needed. Good luck. Steve 8N 169302
