7N279363 Eng S/N
E Leindecker
08-27-2002 08:33:13
I'm trying to identify an old tractor. What I know is:
Grill has Ferguson on it under what I think was a (missing) Ford Logo. Engine S/N is 7N279363.
On the forward side of the left rear axel there is a S/N 2N4015AZ dated 3-3-47.
Above the Steering wheel, a plate says Ford Motor Co with a long list of patents. No S/N shown.
Tractor is painted all grey.
Engine has points mounted on front of engine with what appears to be a magneto mounted above points.
Engine is flat head 4 cylinder.
Three speed trans.
Left brake has foot lever on left side, right brake has foot lever right side.
Clutch foot lever is on left side.
Has plates as foot rests not pegs.
Can anyone help me identify this tractor. Picture available.....
Larry 8N75381
08-27-2002 11:30:02
 Re: 7N279363 Eng S/N in reply to E Leindecker, 08-27-2002 08:33:13
Go to the web page linked below. It should give you all you need to know to identify your tractor.
Eric Leindecker
08-28-2002 06:52:09
 Re: Re: 7N279363 Eng S/N in reply to Larry 8N75381, 08-27-2002 11:30:02
Thanks Larry, that really cleared things up for me. Very good article
1947 2N
08-27-2002 09:42:00
279xxx is a definite 1947 2N model. hand stamping may have skewed the 2 to look like a 7.
Don't be mislead that there was not a 7N model.
A prototype 7N was initiated in 1945 and it was concluded in early 48 or late 47 to call the 7N the 8N.
I have never seen any mention of any serial number stamped 7N. But, that is not to say that some MAY have been stamped 7N in late 47 when Ford vascillated back and forth between calling the newer model a 7N or the 8N.
All this was happening about the time Ford lay dying, and the handshake agreement between Ferguson and Ford was dissolving.
When your rear axles were cast, and the tractor assembled, Ford only lived another month. He died 4-7-47.
Consider a careful look at the serial number on the block, remove some paint, and look for the lower half of the 2.
And, then again, it could be a hand stamp error and the stamper reached for a 2, but had a 7. Unlikely...but you never know.
Eric Leindecker
08-27-2002 09:58:56
 Re: Re: 7N279363 Eng S/N in reply to 1947 2N, 08-27-2002 09:42:00
Thanks to all of you for your inputs. I do agree the Engine S/N is hard to read but, by looking at the 2 the 7 and the 9 in the S/N number the first number appears to be a 7. Now, I'm not totally sure about the N being the correct second digit. But, I don't know any other option for the second digit besides N. The number reads 7N2793 63.
Jim.UT
08-27-2002 14:02:48
 Re: Re: Re: 7N279363 Eng S/N in reply to Eric Leindecker, 08-27-2002 09:58:56
If, after comparing that first digit with the 2, 7 and 9 in the rest of the number you are still sure it's a 7 then you've got a real novelty. Kind of like a postage stamp that gets printed upside down. I don't know that it would increase the collector value any, but it would still be a neat thing to point out to the Ford "experts" at your next tractor show!
Obviously the S/N stamper grabbed the wrong stamp. It should really be a 9.
not a 2 but a 9
08-27-2002 09:43:49
the stamper should have reached for a 9 not a 2. no serial number has a 2N only 8N or 9N.
Dell (WA)
08-27-2002 09:19:25
Linedecker..... ..what waterboy said..... ..
The engine s/n is hand stamped and sometime the number isn't too well struck. ie... a 2 without the underbar could look like a 7 ..... ..Dell
Um...
08-27-2002 09:24:14
 Re: Re: 7N279363 Eng S/N in reply to Dell (WA), 08-27-2002 09:19:25
All 9N-2N serial #s start with 9N...no 2N stamped, so I am assuming (uh oh) that his 7N is really 9N....
yeah . . . you're right
08-27-2002 09:31:35
 Re: Re: Re: 7N279363 Eng S/N in reply to Um..., 08-27-2002 09:24:14
you're right..... a badly struck 9 could look like a wimpy 7 (grin). I agree its a 2N..... .Dell
Water Boy in Michigan
08-27-2002 08:55:50
Looks to me like you got a late model (2N). Mighty fine machine. Only made "9N-2N & 8N".
No such animal as "7-N". On the left of this fine board you see "Gallery" look at "Photo" you will see all kinds of tractors..... ..... HTH.
