Order Ford 8N Parts Online
8N LOCKED UP
GZ MAG TX
08-26-2002 19:16:32
8N will not turn over, tried pulling it with another vehicle, when I let out the clutch, the wheels will not turn, regardless of gear. Searched the archives and was convinced the starter was locked up. I removed the starter tonight and it will still not budge.
With starter removed, I Removed spark plugs(assuming no compression would make things move a little easier) and tried rocking back and forth in 3rd gear but still nothing.
Tried putting tractor in neutral, engaged PTO and tried turning PTO shaft with moderate force, still nothing.
Complete rebuild of engine about 4 months ago and it has been running very smooth. No expensive sounding noises or anything to cause suspicion.
Ran tractor about 7 days ago and all was fine.
Does not appear to be any coolant missing, so I don't think I got any coolant into any forbidden areas that may have casued the pistons to sieze.
Any suggestions?
Dennis N Tx.
08-27-2002 08:16:04
 Re: 8N LOCKED UP in reply to GZ MAG TX, 08-26-2002 19:16:32
Had the same thing happen to me last summer.
Engine was running fine...shut her down for a cool one...went to start her up and it was locked. Tried rocking it...nothing...big screwdriver on the flywheel...nothing. Next I tied it up behind my truck. Had friend pull me down the road with the clutch in I tried 3rd...tires would lock...same in 4th, 2nd. Had to get turned around (out of road)...then I decided reverse (still going forward)...and wallah!! engine turned over (backwerds). I was then able to start it normally. Don't know what happened?? Starter locked is my guess. It hasn't happened since.
Good Luck
Dennis
GZ MAG TX
08-27-2002 09:04:15
 Re: Re: 8N LOCKED UP in reply to Dennis N Tx., 08-27-2002 08:16:04
thanks Dennis
I'll try the "backwards pull" tonight.
Not backwards....Dennis N Tx.
08-27-2002 09:10:58
 Re: Re: Re: 8N LOCKED UP in reply to GZ MAG TX, 08-27-2002 09:04:15
Pull forwards in Reverse gear, it will make engine turn backwards (freeing starter gear is my guess)
FWIW
GZ MAG TX
08-27-2002 09:58:58
 Re: Re: Re: Re: 8N LOCKED UP in reply to Not backwards....Dennis N Tx., 08-27-2002 09:10:58
I removed starter. So I guess this will not make any difference. Thanks for the clarification.
It may not be starter related
08-27-2002 10:07:57
 Re: Re: Re: Re: Re: 8N LOCKED UP in reply to GZ MAG TX, 08-27-2002 09:58:58
could be something else
Evil Steve
08-27-2002 07:27:37
If in neutral you can spin back tires but can't turn the engine even by hand (have you tried?) and the starter is removed eliminating that possiblity, you have a piston that seized or perhaps the cam gear is jammed or a main bearing has seized. Pulling the plugs isn't going to show you much.
Bubba, based on your post and answer to others' questions, I think you're gonna have to get back into the engine. Sorry.
Dell (WA)
08-26-2002 21:13:11
GZ..... ....I know what you wrote makes sense to you but leaves my head spinnin' (grin).
Does the engine even start when you have the clutch down? This is the unclear part.
The rest of your problem description is consistant with tranny shifter problems. Specifically, it is possible to get tranny in 2 gears at one time. This will lock up your tractor big time. You'll have to remove your 8N's tranny top cover and look around..... ....Dell
GZ MAG TX
08-27-2002 05:39:41
 Re: Re: 8N LOCKED UP in reply to Dell (WA), 08-26-2002 21:13:11
engine will not start with clutch down, clutch up, facing towards Mecca, me standing on my head. Will go into neutral just fine and the wheels will turn when in neutral - when I push the tractor.
I am pretty sure the front half of the tractor is what is locked up. Just cannot understand why. I assume that any event that caused the engine to lock up would have been accompanyied by nasty noises.
Dell (WA)
08-27-2002 06:09:53
 Re: Re: Re: 8N LOCKED UP in reply to GZ MAG TX, 08-27-2002 05:39:41
GZ..... ..... ah-haw..... engine won't turn, clutch down. This is symtomatic of hydraulic lock. Check your engine oil dipstick for overfull. And smell it.
Generally when you pull the sparkies and crank the engine you pump the excess cylinder stuff out the hole but in your case, probably has drained down past the piston rings and into your crankcase oil.
Heres the deal. Gravitiy fed fuel and bad carb float can drain fuel tank up thru the intake manifold and in any open intake valve and vola' hydraulic lock when you go to start..... ....Dell
GZ MAG TX
08-27-2002 07:07:53
 Re: Re: Re: Re: 8N LOCKED UP in reply to Dell (WA), 08-27-2002 06:09:53
SO, based on your posts in the archives...
hydraulic lock is caused by coolant in the cylinders...which means new head gasket time?
Current head gasket is only 4 months old(complete rebuild in April) - have not noticed any white smoke from burning water. Guess I'll pull the head and look for rust.
I sure was hoping to get out of this without a visit from the UPS man!
Thanks for your help.
yes . . . Dell (WA)
08-27-2002 09:28:24
 Re: Re: Re: Re: Re: 8N LOCKED UP in reply to GZ MAG TX, 08-27-2002 07:07:53
GZ..... .....engine hydraulic lock could be caused by eather radiator water from a leaky head gasket ..... .OR..... .by gravity fed fuel past a leaky carb float valve.
(you do remember to turn the fuel valve under the tank OFF when you are done using the tractor for a time, don't you?)
Since you reported less than 1" of radiator fluid missing (overflow probably) I kinda discounted the leaky headgasket theory. But check your engine compression if you can ever get the engine to turn over.
AND SMELL your crankcase oil dipstick..... ..Dell
GZ MAG TX
08-27-2002 10:06:08
 Re: Re: Re: Re: Re: Re: 8N LOCKED UP in reply to yes . . . Dell (WA), 08-27-2002 09:28:24
based on yours and "don't" comments, If I can free up the engine, it will be ok?
So either by turing the crank by the pulley bolt on the front or by the flywheel, I can free it up - maybe?
Should I pour a littl MMO into each cylinder to help loosen things up?
Dell (WA)
08-27-2002 12:03:29
 Re: Re: Re: Re: Re: Re: Re: 8N LOCKED UP in reply to GZ MAG TX, 08-27-2002 10:06:08
GZ..... ..... Look...what moves in a good engine? The pistons go up and down, right? What can stop the pistons from going up and down and doesn't make expensive noise? Fluid, right? What are the possible sources of fluid? Radiator water thru a leaky headgasket...OR... Gasoline gravity feed up thru the carb float valve and intake manifold and intake valves.
Why do you seem unable to verify or refute those 2 possible scenarios?
Now besides the pistons going up and down, what else moves in a good engine? The crankshaft goes roundy-round doesn't it? Well what else goes roundy-round besides the crankshaft? Why the crankshaft gear that drive the camshaft gear and the oil pump gear.
What do you suppose would happen if one of the bolts holding the camshaft gear or oil pump gear got loose? Do you suppose a loose bolt just might get wedged into the gear train somehow? What do you suppose might happen if the crankshaft gears got wedged? Do you suppose it just might stop turning?
And how do you suppose you are going to find out? By disassembling the front engine cover? Wonderful, good thinking, go to the head of the class and start there..... ..... .respectfully, Dell, who is outta ideas
don t. - 9n180179....As I understand it....
08-27-2002 09:25:18
....its not antifreeze, its gasoline. If you've got a bad float needle in the carb, gas doesn't get shut off, continues to flow, filling up the manifold and into your cylinders. Don't take this as gospel, im no expert!! Just following the thread.
HTH....don t. ....
Mountainman
08-26-2002 21:12:31
"when I let out the clutch, the wheels will not turn, regardless of gear".
What about in neutral?
Which end is locked up - the engine or the trans/diff?
While standing on the clutch pedal, can the pto be turned? What about in neutral?
Sounds to me like you are in two gears at the same time. If that is true, you should be able to start the engine with the clutch depressed.
A little more info and the experts with be able to pinpoint the problem.
Mountainman...CA
GZ MAG TX
08-27-2002 05:45:03
 Re: Re: 8N LOCKED UP in reply to Mountainman, 08-26-2002 21:12:31
Hello,
Thanks for response, here are answers to your questions:
What about in neutral? wheels will trun in neutral
Which end is locked up - the engine or the trans/diff? I think the engine
While standing on the clutch pedal, can the pto be turned? What about in neutral? Can turn PTO shaft with clutch depressed. I put a pipe wrench on PTO and tried to turn it but it would not turn with tractor in neutral,PTO engaged, clutch out. I did not try to turn it too hard as I don't want to have to replace PTO shaft too.
