Knew I should have knocked wood! An electrical problem
Tom A
08-21-2002 11:26:47
Last week I said my old 48 hadn't given me any trouble in 4 years and now she is. All of a sudden, it is starting problems. Here is what I know, can anybody make a suggestion?
The weather is hot.
The battery doesn't hold a charge; in a few days it'll be too weak to start or entirely dead.
If I hook battery to a charger, it'll go up to 6.48 volts and stay there even though the charger indicates that is only 3/4 charged.
If I check generator output while she's running, it is around 6.7 volts.
Once started, she'll run all day, even start and stop ok.
If I hook an ammeter up between the disconnected ground and the frame there is no current, but a voltmeter shows about 0.8 volts.
Any ideas? Battery gone...or something else?
thanks!
Tom A & Molly
48 8N
Jack - Illinois
08-21-2002 17:41:37
 Re: Knew I should have knocked wood! An electrical problem in reply to Tom A, 08-21-2002 11:26:47
I'm betting on the battery too. But to prove it before you buy, when you stop the tractor remove one of the battery cables. Now if it goes down in a day or two it has to be the battery as nothing is hooked up to drain it.
Upper Peninsual, Mich.
08-21-2002 14:20:59
Hi Tom A. Sounds like you need a new battery. Once you get it started your generator keeps it charged and the engine running. If you stop for a while it has enough charge to restart the engine. If you let it sit for a couple of days, it is discharged. You could either have a bad battery ( my guess) or something drawing current while the tractor is sitting for a few days, resulting in a dead battery. Good luck. Ron
Dave OH
08-21-2002 12:10:09
I would say the battery is bad. Although there is a MA. draw on the battery if you are showing voltage. Set your meter to the MA. range.
Dave OH
Gary '40 9N
08-21-2002 11:30:02
Myself, I would be eyeballing that voltage regulator.
