3 point Lift problems
CCJ
08-21-2002 08:48:50
I have a 1950 8n that has irratic lift problems with the lift arms sometime it lifts very slow or only part way then all of a sudden it will lift so high it pushes my seat up. Any suggestion to fix or adjustments? It has plent of oil. Thanks CCJ
ZANE
08-22-2002 04:00:42
 Re: 3 point Lift problems in reply to CCJ, 08-21-2002 08:48:50
If it lift high enough to hit the seat you have something bent. The lift is not suppose to contact the seat no matter how high it raises.
The other problem is related to the adjustment of the lift linkage etc.
I have a jig and illustrated booklet to allow you to properly adjust the 8N lift.
You gotta have a little mechanical ability though to do it.
See the link below.
