Jubilee PTO problem
Brian
08-20-2002 06:44:47
I was mowing the lawn and decided to dis-engage the PTO before I stopped the tractor. Now the PTO lever will not engage, just makes a grinding type noise as if the gears are not lined up. Does anyone have any ideas about were I should start to fix my problem?
Thanks!
Brian
raytasch
08-20-2002 12:44:42
 Re: Jubilee PTO problem in reply to Brian, 08-20-2002 06:44:47
Brian,
Are you sure you got a Jubilee and not a hundred series with a two stage clutch? Is your clutch releasing?
ray
Brian
08-20-2002 13:10:44
 Re: Re: Jubilee PTO problem in reply to raytasch, 08-20-2002 12:44:42
raytasch,
I'm sure I have a '53 Ford Jubilee. The PTO control lever does go full forward position (OFF) but will not go back to engage the PTO. The PTO does not spin in its current state. The PTO shaft does seem to move slightly inward (towards the tractor) when I try to engage it. Is there a way to check out if it has a two stage clutch?
