Knocking
John
08-18-2002 16:32:36
My 8n had been sitting for about 3 weeks and when I started it I got a pretty load knocking only for about 5 seconds then it ran perfectly I did not see the oil pressure while knocking but it was 30lbs when it smoothed out. Can I put anything in the gas or oil to protect it while sitting its just the greatest tractor? Regards to all
Larry
08-18-2002 19:50:02
 Re: knocking in reply to John, 08-18-2002 16:32:36
Dell is exactly right -
but I wonder... in only three weeks; what weight motor oil are you using?
Regards.
Dell (WA)
08-18-2002 17:13:37
John..... ...sounds like your oilpump lost its prime. Usually the oil pickup tube is becomming un-soldered. Starter every day and maybe you'll keep the prime. OR don't turn on the ignition switch or pull the choke untill you've cranked the engine a few cranks and build up the oilpressure, then lighter' off..... .....Dell
