Order Ford 9N Parts Online
9n electrical problem
Kevin
12-04-2000 12:18:48
Help, I am a 1st time part time farmer and mechanic.
My ford 9n does not get any spark, I replaced the condenser and one of the light switches( I thought it was grounding out) I have power to the starter if I jump it to the cellunoid(sp)I am at a lost. Can anyone provide a step by step instruction to trouble shoot my problem. i would hate to replace my coil,distributer etc.. for something that may be so very simple.
By the way I tested my coil and it seems I have continuity. Please help desperate to finish late fall chores in the winter.
ZANE
12-04-2000 18:07:32
 Re: 9n electrical problem in reply to Kevin, 12-04-2000 12:18:48
One thing that you should do to see if the points are making contact and nothing is shorted out is to either use a volt meter or a test light.(the test light will dim and brighten) and turn the engine over and observe if the current is being broken each time a piston comes to top dead center. No need to know when it is top dead center but just if the voltage is fluctuating as it should if the points are opening and closing.
If the volatge remains high and does not fluctuate then you have an open circuit and it it remains low and does not fluctuate then you have a short somewhere below the coil. Like at the condeser connection to the terminal or the points are not opening at all.
Mitch
12-04-2000 12:29:39
Sounds like you have a wiring problem. go to www.n-series.com and click on the wiring diagrams link. there are diagrams for every model N including 12 volt conversions. Sounds like any number of things could be wrong from a simple wiring mistake to burnt out points. If your N has been converted you will need a resistor to reduce the 12 volt down to 6 volt if the coil was not replaced with a 12 volt one otherwise points will get fried. Check and make sure the wiring is as per diagram then get back to us so we can help.
Kevin
12-04-2000 13:26:09
 Re: Re: 9n electrical problem in reply to Mitch, 12-04-2000 12:29:39
Thanks, Mitch
I replaced the "drop Resistor" but I used a piece of tin foil just to test everything, I might have fried the points as you say How do I check that?
Mitch
12-05-2000 05:33:21
 Re: Re: Re: 9n electrical problem in reply to Kevin, 12-04-2000 13:26:09
Zane's comments will probably help you out more than mine. But you may be like me, I don't understand voltmeter language very well. I'm the type of person that starts replacing parts beginning with the cheapest first. I know that doesn't sound very wise but hey no one ever accused me of being a rocket scienetist before. I would pull the distributor cap off and use my wife's compact mirror to see if the points look blackened. If not and wiring is as per diagram, I would get a voltmeter and start testing components such as the condensor, resistor etc. Not really looking for any certain ohms but just to see if they have continuity. One thing is that you could have the spark plug wires mismatched. firing order is 1243. spark plugs are numbered 1234 going from radiator to seat. distributor is (if I can remember right, I'm at my office and should be working now,)clockwise from upper left 1243. trace your wires to be sure. good luck.
TimK
12-04-2000 13:35:02
Now you've got me curious about this "shade tree" test procedure. How does one use tin foil to check voltage ?
Kevin
12-07-2000 10:36:47
 Re: Re: Re: Re: 9n electrical problem in reply to TimK, 12-04-2000 13:35:02
sorry to mislead you, I used the tin foil in place of the drop resistor.
Is it possible that my ingnition switch is grounding out the system?
