Order Ford 9N Parts Online
9N wont stay running
Neil
08-12-2002 19:39:52
Hope someone out there can help. I recently had to replace the water pump on the tractor. After I put it all back together, the tractor started right up but only ran for about 5 minutes. I let it sit a few days, and was able to get it to start again. Again it only ran for a few minutes. A few days later I replaced the points with proper 0.015" gap, and the condensor. Also changed the plugs. The tractor then started and again only ran for a few minutes. The next day I changed the coil. The tractor again started right away but only ran for a few minutes. It doesnt misfire and I have fuel available. It never gave me problems before the water pump went out. Can someone please help me? Thanks in advance.
Dave OH
08-12-2002 20:56:38
 Re: 9N wont stay running in reply to Neil, 08-12-2002 19:39:52
Other posts are right, fuel. Alternative: When it stops pull a plug ang ground it to the engine to see if you still have spark.
Dave OH
DON TX
08-12-2002 20:45:55
Just a guess, check the ignition switch. Sounds like typical bad switch. Jumper it and see if it will stay running longer. HTH
DON TX
Rick
08-12-2002 20:33:13
Make sure your gas cap vent isn't corroded.
The tank could be creating a vaccum.
Allen in Oregon
08-12-2002 20:07:51
Neil, You say you have fuel but are you sure you have enough flow? Check the three fuel screens, One in the fuel line elbow at carb, one in fuel tank at top of fuel shut off and one in the sediment bowl below fuel shut off. Sometimes fuel will flow through but not fast enough to keep up with engine needs. Hope this helps. Allen (;>)
Ken N Tx
08-12-2002 20:04:40
Sounds like a fuel problem...Check the three filters (tank/bowl/elbow)..Ken
Clay-8N's
08-12-2002 20:00:07
Could there be any water or coolant getting on or in the distributor????
