Ok, I think I may have found my no start problem. Progress...At the bottom of the valve stems (adjustable) there is a cup to hold the bottom of the spring, inside this are two half round inserts that hold the valve stem in place. Wish my digital camera worked... On #2 you could see the valve stem on top of the lifter. On 1, 3 and 4 you couldn't, all I see is that cup (sorry for my lack of correct terminology). What happened was that those half round inserts somehow slipped up on the valve stems. Is this a common problem, or have I installed them improperly?? I need to order a new manif gasket and cover gaskets so I have time to work through this (pout) anyway. I know, I really need that tractor manual. I never received it with my parts order and decided to plunge in anyway. bad idea. I'll bet my last dollar (and thats about what I have left) that these inserts are the issue with it not starting. I now have no compression in 1, 3 and 4. and the bottoms of the #2 valves look much different than 1, 3 and 4. I can see a bright silver piece between the lifters and the valve spring on #2. I'm really concerned that there is a problem with this type of adjustable lifter setup. Anyone had any problems with this before? -Mike
