3-point upper lift arms drop too low
Gary '40 9N
08-10-2002 15:28:40
What would cause the upper lift arms to drop too low? My leveling box rests right on the axle trumpet when the lift is all the way down. It has worn a little divot in the trumpet. I thought it was due to that arm being bent a little but I have replaced the arm and it still hits the trumpet. A bent connecting rod between the piston and the shaft arm maybe? Or a bent arm? Must have been overloaded at one time. Hydraulics work great. Just this little pain in the butt.
Mountainman
08-10-2002 22:17:52
 Re: 3-point upper lift arms drop too low in reply to Gary '40 9N, 08-10-2002 15:28:40
My 8n's leveling box will rest on the trumpet if I don't have an implement attached. Since you have a divot why not fill it with epoxy - won't last forever but easy to redo in a few years.
Been following your "rebuild" story - great photos. Nice work on the N
Mountainman...CA
Rusty 2N
08-10-2002 17:11:12
What Levi said. Once you hook something up it wont go that low,
Levi (WA)
08-10-2002 17:01:01
Gary, All my Ns are that way too,
Zane said this, about that, "it is normal if it aint broke don't try to fix it"
