Sir Dell, I'm going to step out on a limb here while I chop it off.....however.... I must respectfully request that you drop #'s 3 and 4 from yer list of good reasons a front-mount electronic disti conversion doesn't exist. 1) True. Insufficient market. Not enuff TAM to justify development. 2) True. Weird design of the integrated coil/disti makes it different partitioning than most cheapo kit solutions. 3) Here it gets ugly. Transistor size is NOT an issue. Big metal TO-3 packages, maybe, but SMT D-paks and other ceramic power packages can dissipate 100's of watts in sizes that are so small you can't print a part number on them. In the front-mount case, the ambient heat is a silicon killer no matter what the package, but it's not nearly as problematic as the delamination of the coil under that heat... 4) Now cut that out!!! You can easily saturate -any- bipolar transistor on a 6 volt supply, and it's just as happy to run in linear mode biased anywhar in between. In fact, many bipolar silicon processes and even moreso in MOSFETs are limited to 20-25V max., and some power switchers can't use gate voltages higher than 10V without damage.. In an HEI or CD ignition, the dynamic switched coil current spike on the primary side don't look much different on 6V vs. 12V. But reasons #1 and #2 are sufficient to justify the reason there is no electronic ignition for my frontmount 8N!!! God bless Dell anyhow for all the right reasons!!!! (I'll crawl back into my hole now!!)
