Live thang
forder
08-07-2002 04:58:35
i have an 8n that i want to instal the live thang on but i dont know where it mounts or drives off of. the tractor has a few other accesories on it already,a second alternator that puts out 110,i dont want it to interfere with anythinng else and the website has no pictures or even many details about the product, could someone who has one post a pic or atleast fill me in on where it mounts, size etc.
ZANE
08-07-2002 05:53:38
 Re: live thang in reply to forder, 08-07-2002 04:58:35
The LIVE THANG live hydraulic unit pump is mounted between the water pump and the generator and is belt driven.
The intake oil line comes from the drain plug in the differential and enters back into the test port of the belly pump. The three point hitch is operated through the original control and relief valves.
Keith_MD
08-07-2002 06:59:46
 Re: Re: live thang in reply to ZANE, 08-07-2002 05:53:38
Zane, Do you need to remove the top cover for any reason with the installation of the live thang. Is it simply bolt the pump on, slip on a new belt and plumb up the supply and output lines? Does it matter what year 8N you have, or are the pump mount brackets universal for early 8's with the gen on the right, and late 8's with the gen. on the left. I am seriously considering your live thang, and would also like to know more about it before I make the leap. Also, are parts to reapir it easily obtainable? Thanks... Keith
ZANE
08-07-2002 17:07:18
 Re: Re: Re: live thang in reply to Keith_MD, 08-07-2002 06:59:46
There are two different brackets for the N tractors. One is for the tractors made before somewhere in 1950 before the side mounted distributor and the other is for the later side mount distributor model.
Nothing has to be removed but the oil to install the system and yes you can get the parts to repair it if it should fail. The only thing that should possibly fail way down the road would be the pump and as of now they are readily available.
These pumps I use appear to be well made and so far trouble free.
forder
08-08-2002 05:03:01
 Re: Re: Re: Re: live thang in reply to ZANE, 08-07-2002 17:07:18
can you still run the heavy oil that you normaly would in the rear, seems a bit thick to pump with a hydraulic pump
