Inside View 2N
duey in MN
08-06-2002 20:08:19
third party image
Test image** The inside view of the diff. housing during lower arm pin replacement... for oil leaks.
duey in MN
08-07-2002 07:21:41
 Re: Inside View 2N in reply to duey in MN, 08-06-2002 20:08:19
third party image
This is what the ring gear looks like. Seems to be a bronze-like plating. The rearend is quiet during operation, has never had any internal troubles in the past, and regarding wear, seems to only show as shiny on gear contact faces. Rivets are tight and original.
Willy-N
08-06-2002 22:17:09
third party image
This is what the pinion should look like when you pull it out. The dark color on yours looks like it has been running hot! This gear was only wiped off and is out of a 8N but they are the same. PS I do not have one for sale. Mark H.
Willy-N Ring Gear Picture
08-06-2002 22:27:00
 Re: Re: Inside View 2N in reply to Willy-N, 08-06-2002 22:17:09
third party image
Here is the matching ring gear. Mark H.
Rusty 2N
08-06-2002 20:48:47
Hey!! Looks just like mine!! was doing the same thing last night. I agree with BG on the gear though. Your pto shaft has the same wear mark as mine but not as deep as mine. Did your ring gear ever cut loose on you? Now to put them back together.
bg
08-06-2002 20:11:08
Looks like the pinion gear has right much wear on it....
