Order Ford 8N Parts Online
8N Boards On A 9N?.....You Bet! (pics)
Mikey
08-05-2002 13:24:18
In my book, the running boards for the 9-2N aren�t the most attractive looking things. Several people have asked about mounting 8N boards on the 9-2N, so I modified some to fit.
Left Side
third party image
Right Side
third party image
Close up of left side
third party image
I removed the rear mounts and took them to my local welding shop. The mounts were lengthened 1� on the bottom (horizontal) leg and the holes were moved out ��. This left enough room for the clutch rod to run behind the running board. I also moved the right board out so everything looked even. I didn�t do it yet, but I need to remove part of the left boards inside lip to get another 1� of pedal movement.
Cost? $20.00 for the new rear mounts.
My nickels worth,
Mikey
Jeff in TN '47 2N
08-06-2002 08:28:44
 Re: 8N Boards On A 9N?.....You Bet! (pics) in reply to Mikey, 08-05-2002 13:24:18
What year is your 2N? Mine came with a set on it and You can tell it never had a set of pegs on it.
Mikey
08-06-2002 11:05:13
 Re: Re: 8N Boards On A 9N?.....You Bet! (pics) in reply to Jeff in TN '47 2N, 08-06-2002 08:28:44
1941 9N, S/N 9N53623
Rusty 2N
08-05-2002 14:53:50
Proud of that tractor aren't you. :)) You should be!! It does look better live than in the pic.
Mikey
08-05-2002 19:33:56
 Re: Re: 8N Boards On A 9N?.....You Bet! (pics) in reply to Rusty 2N , 08-05-2002 14:53:50
Proud? Yep, I guess.
I figgered the shots showed the boards good enough. Some day I'll get a better camera and take a good photo!
Mikey
Jay 2NSC
08-05-2002 14:49:12
Looking really sharp Mikey!Thank you for that information.I've got ot do that to mine.One question,on your steering arm's did you rebuild them or just replace the packing? Jay 2NSC
Mikey
08-05-2002 19:01:14
 Re: Re: 8N Boards On A 9N?.....You Bet! (pics) in reply to Jay 2NSC, 08-05-2002 14:49:12
ay,
If you are talking about the rear tie rod ends, they were good and tight so I soaked them for a couple of days and replaced the zerks. If you mean the steering sectors, I replaced both of the seals on each side and shimmed everything up tight. Roughly 1/2 inch play before the front end starts to turn.
Mikey
Levi (WA)
08-05-2002 14:38:51
Nice job on the pictures...oh and the running boards too. I saved the boards off the 8N I'm parting out to install on my 2N.
