3 point raises well when tractor is moving, but...
jimmyp
08-04-2002 20:05:01
I have a 48 8n with a 5ft mower that seems to work well, but the 3 pt won't lift the mower unless the the tractor is moving and open throttle, then she lifts pretty well. At a stop, in neutral, pto on and clutch out with throttle open, the arms try to move up but stop when the weight starts. Is this a part or a worn out pump. thanks for any help, jp
ZANE
08-05-2002 04:13:38
 Re: 3 point raises well when tractor is moving, but... in reply to jimmyp, 08-04-2002 20:05:01
Sounds to me like the lift needs to be adjusted and the cam follower pin replacedd probably too.
Also you could have a leakage of pressure somewhere internally in the hydraulic system.
See the link below.
Willy-N
08-04-2002 21:37:31
Check the Arcives in this Board there are tons of posts with resons and fixes for this type of problem. It may be your piston is leaking that would be the first thing I would check, take the plate off the side with the dip stick and while running with something being lifted look up at the piston to see if it is leaking. You can use a mirror and flash light if needed. Mark H.
