A couple more photos ( hey, the lighting was good )
Gary '40 9N
08-01-2002 16:17:02
third party image
Well, I didn't get much done today. I had to make 2 trips to the machine shop before he was done with my pin and the weather was just too darn hot to be out in it. I did get the inside of the hood cleaned, treated and painted tho. I even got the gas tank back in after the paint dried a bit. Maybe tommorrow I will start work on the outside of it. I am still waiting for my bushing driver hence the spindles are still apart. I guess I should fill that radiator now that it is on for good. I hate to spill anti-freeze on my freshly painted hood when it is done.
watchwinder
08-01-2002 20:45:34
 Re: A couple more photos ( hey, the lighting was good ) in reply to Gary '40 9N, 08-01-2002 16:17:02
looks good gary, im proud to see someone restore a 9n and paint it the color its supposed to be..have fun ww..
duey in MN
08-01-2002 19:15:49
Looking like fun there, Gary. You going to stay with the 'pusher' fan? And do you happen to know when they used a 6 blade fan?? That 6 blade was a 'puller', if I recall.
I think it's easier to keep the radiator clean with a 'puller' fan... brush hogging in dry conditions it seems to collect alot, but sometimes just shutting it off lets in most all fall out. Duey
Jim.UT
08-01-2002 21:05:17
 Re: Re: A couple more photos ( hey, the lighting was good ) in reply to duey in MN, 08-01-2002 19:15:49
I thought it was just the opposite: 4 blade = puller fan (pulls air from the front) and 6 blade = pusher (pushes air from the engine back out the front of the rad). I know my 850 4 blade fan blows an impressive breeze back in my face while I sit on the seat. I'm no expert and I could be wrong.
duey in MN
08-02-2002 00:04:07
 Re: Re: Re: A couple more photos ( hey, the lighting was good ) in reply to Jim.UT, 08-01-2002 21:05:17
On Gary's picture below, it looks like a 4 blade pusher to me. At our "old place" many years ago, there was a 6-blader hanging on the wall, but that was too long ago & I can't recall which direction it moved the air. I don't think it came along when we moved.
I wonder they didn't move TOO much air & waste an extra HP or two.
Gary '40 9N
08-02-2002 04:56:56
 Re: Re: Re: Re: A couple more photos ( hey, the lighting was good ) in reply to duey in MN, 08-02-2002 00:04:07
Yes, it is a pusher fan. Kinda funny to see grass and stuff bow down in front when I go for a putt. My '46 2N had a 6 blade fan on it when I got it but it was a puller. The previous owner of that tractor must have straightened that fan a couple times after it munched the radiator because one day when I was down at the corner gas-up, the pulley it is bolted to came off the shaft along with the fan and trashed my radiator! I had to buy a 4-blader because I couldn't find a 6-blade fan.
Gary '40 9N
08-01-2002 16:21:17
third party image
Look behind the tractor in this photo and you can see a little of the nasty looking hood. The last couple of paint jobs were brushed on and are THICK! Notice the nasty yellow primer. Funny thing, the paint stripper wouldn't even touch the first 2 layers of paint. I have a lot of prep work on that hood to do. I got my decals on too.
Tyler (MD)
08-01-2002 16:46:50
 Re: Re: A couple more photos ( hey, the lighting was good ) in reply to Gary '40 9N, 08-01-2002 16:21:17
Gary,
What was the s/n of your 9N? I can tell it's early on the count of that dip stick on the top of the tranny housing.
Tyman
daz
08-02-2002 03:38:06
 Re: Re: Re: A couple more photos ( hey, the lighting was good ) in reply to Tyler (MD), 08-01-2002 16:46:50
Number 25723 daz Ohio
Gary '40 9N
08-01-2002 17:00:05
My 9N is serial number 31701. I figure it was run down the assembly line about July or August of 1940.
