134 engine vrs 172 engine
Smitty
08-01-2002 16:04:31
What are the differences in these 2 engine, sleeve size and carberation ??
Also Mark H please contact me about fire safty, I live in the forest also and would like some tips
Smitty
08-01-2002 17:06:37
 Re: 134 engine vrs 172 engine in reply to Smitty, 08-01-2002 16:04:31
Thanx everyone, I was wondering if I could modify a 134 into a 172 next time I rebuild one, looks like a sleeve amd manifold change so far.
snitkawl
08-02-2002 04:11:08
 Re: Re: 134 engine vrs 172 engine in reply to Smitty, 08-01-2002 17:06:37
The bore of a 134 is too small to accept the sleeves from a 172. I think the blocks are the same and it might be possible to bore the 134 block out enough to use 172 sleeves.
Jim.UT
08-01-2002 20:25:58
The guy you should talk to is Tony Jacobs over on the Ford board. He's pretty busy and sometimes only checks in every couple of weeks, but he knows these hundred series Fords inside and out. He'd be able to tell you how much work it would be to enlarge a 134 to a 172.
raytasch
08-01-2002 16:22:15
134 measures 3.44" x 3.60"--48.8 brake HP
172 measures 3.90" x 3.60"--62.6 brake HP
Carburetion is the same although jet size may be different.
Source: Ford Tractor Shop Manual 1955-1960
Hope this is what you're lookin' for.
ray
Jim.UT
08-01-2002 16:57:58
 Re: Re: 134 engine vrs 172 engine in reply to raytasch, 08-01-2002 16:22:15
According to info on Dan Dibben's site, carburetors are different on 134 and 172 engines. Stud spacing is different prohibiting interchange of the two. It also says that main jet sizes differ according to engine size. But then further down the page there is a table showing carb specs and the jet sizes look the same, so I'm kinda confused. I know my 172 equipped '55 850 has a Marvel-Schebler TSX593 on it.
buck
08-01-2002 19:16:12
 Re: Re: Re: 134 engine vrs 172 engine in reply to Jim.UT, 08-01-2002 16:57:58
I replaced the cracked manifold on my NAA (134) with the manifold off a 172 and had the elongate the holes just a tad for a good fit for the NAA carb.For all practical purposes I would say that they are interchangable but the 172 manifold would flow better for the larger pistons.
raytasch
08-01-2002 18:42:24
Jim, I just measured the stud spacing on my Jub and my 850 and they both measure about 2 3/8" center to center. Of course, it is dark in the shed and the flashlight could have caused me to be unable to read exactly. Dan may and is probably right on that if he stated it. I have not been to his site in a looong time. I have never noticed any differences between the carbs on the two tractors. I can not see the #s on the carbs, both MS.
ray
Ed Gooding (VA)
08-01-2002 16:18:42
Hey Smitty. See if this will give you the info you need:
third party image
third party image
Hope this helps..... ..... .Ed
'52 8N475798
Jim.UT
08-01-2002 16:06:51
Here's some engine specs. Poke around the site I've linked and I think you'll find carburetion info, too.
