Order Ford 8N Parts Online
8N c/w original accessories
ThompsoN - pics
07-31-2002 12:01:51
This is the first of several threads. I put each model of tractor in a separate thread. Oh yeah, each tractor you will see was owned by the same man.
This 8N had the original sickle bar and a Dearborn plow.
third party image
As you'll see, this guy had every emblem on all of the tractors. Everything original and a sight to behold.
third party image
Watch for threads on the tractors you see in the background.
Don (NC)
07-31-2002 12:18:17
 Re: 8N c/w original accessories in reply to ThompsoN - pics from Quebec show, 07-31-2002 12:01:51
Everything original except the front bumper and those strange headlight mounts?
Dave OH
07-31-2002 17:45:48
 Re: Re: 8N c/w original accessories in reply to Don (NC), 07-31-2002 12:18:17
OK Don, what does the "original bumper" look like?
It certainly not what is being sold on E-Bay.
My brother-in-law has what I considered an original 8N bumper on his complete original 8N tractor. It has 4 mounting holes to the tractor, the second from the bottom bar is heavier than the rest and it has a piece welded in the center behind the heavy bar with the protruding part for a hitch ball or pin for extra support. Thanks in advance for your time,
Dave OH
[email protected]
Don (NC)
07-31-2002 18:11:06
 Re: Re: Re: 8N c/w original accessories in reply to Dave OH, 07-31-2002 17:45:48
Actually, there is occasionally an original bumper at auction on ebay...
Take a look at John Smith's site below for some good shots of an original bumper. The home page has a good one, then select Accessories from the bottom of the page. Scroll down on that page and you'll find another good closeup.
The key thing to look for is the bar that bolts to the axle has a slight S curve bend downward on the sides. There is only one bolt hole on each side.
Also search the archives...there have been a lot of posts about the bumpers and someone put out a schematic of the dimensions so you can construct your own.
RICKWI
07-31-2002 16:55:02
Notice a lot of those goofy triangle brackets on N's in the Newsletter. Why? Does't make the lights closer together for loader application. Sure doesn't look better. Maybe the mounting holes are ripped out and it is an easy way to cover?
Dave iN Alberta
07-31-2002 19:54:54
 Re: Re: Re: 8N c/w original accessories in reply to RICKWI, 07-31-2002 16:55:02
I wish I had goofy looking headlight brackets. Then maybe I'd have something to put my headlights on. But that's just my way of thinking. Me and my 2N...not as good as new, but both perform when asked.
LMAO, Dave
JD
07-31-2002 18:00:26
Those were the original mounting brackets that came with the lighting kits sold in Canada. Don't know why they were different than the US kits, but they were.
Don (NC)
07-31-2002 18:14:02
 Re: Re: Re: Re: 8N c/w original accessories in reply to JD, 07-31-2002 18:00:26
So they could be considered original. I stand corrected. I forget, did any N's come from the factory with lights or were all the lights installed by the dealers?
JD
07-31-2002 18:59:07
 Re: Re: Re: Re: Re: 8N c/w original accessories in reply to Don (NC), 07-31-2002 18:14:02
All lights were installed by the dealers.
StuartK
07-31-2002 17:49:31
Hey! some sensitivity please! Mine has those goofy brackets on the lights! I think a lot of those got put on by the dealers as I've seen a few here in Canada with them on. Oddly enough my rear work light has a cast deco winged bracket on it. StuK
ThompsoN
07-31-2002 12:26:04
Sorry Don, can't fool the pro's I guess. I hadn't noticed the mounts but I'll retract the "everything" original.
