Order Ford 8N Parts Online
8N CARB
COLBY TX
07-29-2002 15:55:05
I CLEANED ALL THE RUST FROM NY TANK AND CLEANED THE SCREEN IN THE CARB FUEL INTAKE. RUN GREAT BUT AFTER MOWING, I SHUT IT OFF AND GAS WAS RUNNING OUT PRETTY FAST AND NOT FROM THE FUEL LINE CONNECTION. I HAD TO LEAVE SO I JUST SHUT THE FUEL OFF. CAME BACK 2 DAYS LATER, TURNED ON THE FUEL, NO LEAK. RAN IT FOR ABOUT 10 MIN. AND SHUT IT OFF, NO LEAKS? DOES ANYONE KNOW WHAT MIGHT DO THIS DECAUSE I DON'T WANT A FIRE OR TO DUMP GAS IN THE YARD?
Dan
07-29-2002 17:03:48
 Re: Re: 8N CARB in reply to Dave Manley, NY, 07-29-2002 16:41:30
It only takes a very small kernel of dirt in the float valve to keep it open ,so then the fuel just runs out .
The flow of the fuel, vibration of engine ,etc. likely caused the valve to clear itself .
COLBY TX
07-29-2002 17:47:04
 Re: Re: Re: 8N CARB in reply to Dan, 07-29-2002 17:03:48
THANKS FOR THE SUGGESTIONS!!!!!
