12 volt wiring problem
Steve
07-28-2002 16:20:45
I just bought a 8n with side mount Dist. It has been changed to 12 volt. It is not charging. I took alternator and had it checked and it is ok. I thing wiring is fouled up. I'm not much for wiring, so I would appreciate any input.
Bill W.
07-28-2002 17:46:30
 Re: 12 volt wiring problem in reply to Steve, 07-28-2002 16:20:45
Steve: hook up with the link below and have fun. good N-ing.
Allen in Oregon
07-28-2002 16:41:43
Steve, go to the top of the page and do a search in the archives on 12 volt wiring diagram. There are serveral ways to rewire an 8n for 12 volts, thus you will find several different diagrams. Find one that matches your application ( or as close as you can) and then look for and repair the problem. I completly rewired my 8n using one of the diagrams and havent had any trouble since. Hope this helps. Ask again if you need more help. Good luck!
