Order Ford 8N Parts Online
8N Cuts Our Under Load
Carleton DJ
07-25-2002 10:46:37
I have a 1948 8N (front distributor) tractor. It runs fine until put under a hevier-than-normal load. After the tractor has run a bit, when it is put under a load it cuts out for a second or two, then starts back up. I find this happening when I cut grass with the brush hog that is a bit taller than normal, for instance.
I read some previous posts, and most people say to look for a fuel flow restriction. Here is what I have done:
I disconnected the fuel line to the carburetor and let the fuel drain out. It flowed freely, leading me to believe there is no restriction of fuel before the carburetor. There is no fuel filter in the line, and the sediment bowl was pretty clean. There is a filter in the little 'elbow' that screws into the carburetor. This filter had a couple pieces of rust/debris in it, but not enough to block the fuel flow significantly.
Do you have any other ideas of where fuel flow could be restricted, or if certain carburetor conditions could cause this to happen? Any suggestions would be greatly appreciated.
DJ
Dave OH
07-26-2002 16:06:22
 Re: 8N Cuts Our Under Load in reply to Carleton DJ, 07-25-2002 10:46:37
All the comments were sound advise. But I had a similar problem and turned the high speed jet out a half turn and it solved it.
Then I started to think why would it start to do this now? I cleaned all the filters. So I added "Gum Out" to the fuel for a few tanks then turned the jet back to normal and all was well.
Might have been dirt in the economizer or by the jet seat.
Dave OH
Rusty
07-25-2002 18:39:02
Carlton,
She should hog through tall grass no problem. After you change points and condensor be sure to adjust the timing (cheap). Also, you had some rust in the elbow filter. Consider draining the tank and removing the sediment bowl assy. Then blow it out with air (free).
garmo
07-25-2002 14:29:45
Carleton - I just had this very problem on a 50, side mount N. It felt like fuel restriction to me, but Evil Steve and one other guy whose name escapes me, said to replace the points and condenser. I did! Wham! She has never run better. There were also other suggestions about what could go wrong. I started with the easier ones first. My money is on the points and condenser. Good luck.
Terry Alexander - dbl ck carb elbow!
07-25-2002 12:44:30
Carleton,
I had some of the same problems. Mine was in the elbow that goes into the carburetor. The way to check is:
Turn the gas off.
Disconnect the fuel line from the elbow.
Remove the elbow from the carburetor.
Re-attach the fuel line to the elbow (now free from the carburetor).
Turn on the gas.
The gas should run freely all the way through the elbow.
This takes as long to type as it does to actually do, but once you have done this, you will have positively confirmed that you have good fuel flow from the tank to the carburetor.
If that doesn't work....then Evil Steve is on the right track.
Terry Alexander - 1950 8N
Evil Steve
07-25-2002 12:05:44
Dying under load, two things to check:
1) Fuel/air mixture adjustment
2) Weak sparkies - point gap/condition, bad coil (common problemon front mount dist's, condensor, plugs/plug wires.
Refer to your Ford I&T manual which has a good section on troubleshooting engine cutout problems..
