Order Ford 8N Parts Online
8n-pto
chip
07-24-2002 20:22:49
how do you remove the pto over run coupler?
Allen in Oregon
07-24-2002 21:39:55
 Re: 8n-pto in reply to chip, 07-24-2002 20:22:49
Remove the two grease zerks and drive out the rolled pin with a punch and slide the orc off the shaft. Hope this helps.
DBay
07-25-2002 06:22:30
 Re: Re: 8n-pto in reply to Allen in Oregon, 07-24-2002 21:39:55
Since the coupling rotates make sure you line up the pin with the removed grease zerks. Nothing worse than banging on perfectly good steel that isn't a pin.
DBay
chip
07-25-2002 09:16:08
 Re: Re: Re: 8n-pto in reply to DBay, 07-25-2002 06:22:30
Thanks guys.
