Order Ford 8N Parts Online
8N Ford Tractor
Tim Alexander
07-22-2002 11:36:11
I have an 8N Ford Tractor with a spring and a shock absorber under the seat. I would like to know if that is a stock item or an after market item. And where could I find information on after market items to add to my 8N tractor. Any information that anyone could give me on this would be greatly appreciated.
Thank you.
CJ in MICHIGAN
07-22-2002 14:27:25
 Re: 8N Ford Tractor in reply to Tim Alexander, 07-22-2002 11:36:11
Mine came with one too-pretty comfortable.
Ed Gooding (VA)
07-22-2002 12:19:44
Hey Tim. Sounds like you have the Monroe E-Z Ride seat, which was an optional seat sold by dealers. There is some info in the archives from folks who have tried to find a replacement for the shock absorber. Here's an original ad for it:
third party image
Here's a consolidation of info supplied by other forum members who have refurbished theirs:
Monroe E-Z-Ride Comfort Seat Option
I tried last spring to find this shock with no luck. My shock had stamped the following information:
Monroe Auto Equipment Company
Monroe, Michigan USA
patent number 2,004,380 & 2,078,364
10B8
OF6-E1
18144
Dimensions of the shock follow:
6.38� compressed center to center
8.00� extended center to center
2.06� large cover diameter
1.68� small body diameter
Retaining ends are as follows:
1.44� OD
1.00� BORE
0.94� WIDE
The number for Monroe is 1-800-879-0540
I also tried a couple of different auto stores with no luck. I finally just painted the old one and put it back on.
I did replace the rubber bushing with some pieces I got from NAPA. The rubber bushings were 2-piece rubber snubbers, number 215 for 0.62 shoulder bolt. I did have to modify the rubber pieces to fit the taper inside of the shock mounting bore.
The Monroe E-Z Ride spec sheet I have doesn't list any dimensions. But it does have part #'s.
9N/8N #16041
NAA #16074
Monroe also made seats for: AC, Case, Corbitt, Co-op, Custom, Farmcrest, Ferguson, Gibson, IH, Inter-Continental, JD, Long, Massey-Harris, MM, Norse, Ostenberg, Oliver, & Sheppard. The brochure states they sold over 600,000 in 4 years.
Hope this helps..... ..... .Ed
'52 8N475798
Levi (WA)
07-22-2002 12:03:55
Have a look through John Smith's site he has tons of info
Mike S
07-22-2002 12:02:39
Both that seat and the rest-o-ride seat were aftermarket, but available at the Ford dealer. There is an amazing amount of things that were made for these tractors. I think someone mentioned over 400 implements and doodads were being sold.
