BROKE MY 600 INTO TODAY TO REPAIR THIRD GEAR IN FIVE SPEED TRANSMISSION
ZANE
11-28-2000 19:37:57
third party image
I finally got around to breaking the 600 into today so I can repair the third gear. It was jumping out of gear. I have $550.00 worth of parts that will fit into a small lunch box to install.
I also did me redesign of the shift rail for the third gear so that it will push the coupler further into the third gear and not just be barely catching the teeth of the third gear like all of them do on the five speed transmissions. It is a design flaw.
I weld up one side of the detent notch and then take out some from the other side of the notch so it will be about 1/8" deeper into third gear when the detent is in the new notch.
Note that I have pulled the front of the tractor off with the hood etc still assembled. This is the only way to go. I did it alone in about 45 minutes. Just hook a chain to the center of the steering shaft and lift till the engine and the transmission are about the same height after everything is removed as shown in the picture.
This will work with the 8N too but you don't have to use the rope over the hood and pan because the battery box etc will support the weitht of the engine etc. I have done this at least a hundred times and no damage will be done to any of the components of the tractor.
Note the rope around the hood and the bottom of the oil pan to help support the engine.
Jim Ryan
11-29-2000 10:35:10
 Re: BROKE MY 600 INTO TODAY TO REPAIR THIRD GEAR IN FIVE SPEED TRANSMISSION in reply to ZANE, 11-28-2000 19:37:57
I have been following with great interest your saga of the 5 speed tranny in your 600, because I have an 850 with the same problem and probably most of the 5 speeds still alive suffer this problem. My question is this, is the shift rail hardened steel? and can it be removed without dis-assembling the whole tranny? My third has a chipped tooth but I think I can live with it if I can re-configure the shift rail somehow,thanks and good luck with your endeavor Jim
ZANE
11-29-2000 18:54:57
 Re: Re: BROKE MY 600 INTO TODAY TO REPAIR THIRD GEAR IN FIVE SPEED TRANSMISSION in reply to Jim Ryan, 11-29-2000 10:35:10
third party image
Thought some of you guys might like to see what I did to modify the shift rail on the third and reverse fork so that it will go further into third gear. I welded it up and the ground it back out about 3/16" farther out toward the end of the rail. It looks good before I sealed it up when in third gear. Hope it works as good as it looks.
ZANE
11-29-2000 16:47:31
I have got it back together but have not installed it in the tractor yet. I shifted it into third gear with the cover off and it looks good to go and is going into the coupling spline about 3/16" deeper than the factory did it.
Yes the shift rail is hardened but I welded the detent up with my little wire welder with flux cored wire and no gas. It is at the end of the shift rail and should not cause any problems with the shift rail breaking etc.
Yes, you will have to break the tractor at the rear to remove the shift rail. It would not have to be broken at the clutch housing but at the rear of the transmission which is a lot easier job than at the clutch. My old third gear did not have any broken teeth and if I had it to do again I would not buy a third gear and just fix the shift rail so it would go deeper into gear. I was not pleased with the parts that I bought from one of the online parts places for Ford parts. I spent about $500.00 on the third gear and the two other parts. The third and rev. coupling and the slider spline. The new copling and the slider has as much play in them as the old ones had. The gear did not wobble as much as the old one though.
After all is said and done I wish I had just bought the used one from the bone yard and taken my chances with it.
I'll post a picture of the modified shift rail later. I left my camera out at the shop and will have to go get it and file the picture on the computer.
