1989 Cub Cadet Hydro static won't move.
Cory
07-16-2002 18:37:50
My dad has a 1220 series cub cadet and it just quite moving on him when he was cutting grass. The linkage is all connected and adjustments are okay. We have no experience with the hydrostatic transmission. Any ideas on what to try next? Someone said change oil and filter. Can anyone explain how hard that is or if it is necessary?
Richard
07-17-2002 19:35:59
 Re: 1989 Cub Cadet Hydro static won't move. in reply to Cory, 07-16-2002 18:37:50
I have a yard pro with a hydro stat that stopped climing hills for me. It was air locked. Apparently the sump for the hydro pump sucked in air at the 30 degree angle I was mowing at. I followed the procedure from manufacturer for working the air out of the system and it worked for me. Check your owner's manual for such a procedure.
steve MI
07-17-2002 02:39:08
all hydro's have a lever to take them out of gear so they can be moved manualy, maybee this kicked out of gear, my old wheel horse was near the shifter and I pushed it foreword to move the mower around by push power, if you have a book look it up, or call a dealer if you don't have the book.
Jack - Illinois
07-16-2002 21:19:50
If it just quit while running, I would look to see if the shaft is turning at the imput to the transmission. Most have split pins or some type of shear device that breaks occasionaly. Low oil or dirty filter won't stop them all of a sudden.
Jack - Illinois
07-16-2002 21:18:59
