Order Ford 8N Parts Online
Levi how is your 8N coming? You should see mine!!
Willy-N
07-16-2002 13:50:28
Levi; You better get moving! I got your grill off. Heck I started at 10:00AM and have allready removed the hood, dash, steering box, carb, manifold, radiator, radius arms, drag links, govenor, oil lines, filter, generator, exsaust pipe, air cleaner, battry tray, tool box, all carb linkage, starter and cleaned some of them for eBay in 3 1/2 hours! Found out the gauges are original too! I will split that baby tomorrow after I pull the front axle support off it. Let me know how your coming. Still hot out!! Mark H.
Levi (WA)
07-16-2002 14:51:46
 Re: Levi how is your 8N coming? You should see mine!! in reply to Willy-N, 07-16-2002 13:50:28
Well My 8 isn't comming apart as fast as yours, I'm gonna have to pull the manifold and tappet covers and look at the valve movement...hey do you know if the first/front manifold stud is in a water jacket, it wants to come out with the nut. I changed the oil in my 2N today, Its a balmy 90 outside 73 inside...grin...
Willy-N
07-16-2002 16:15:37
 Re: Re: Levi how is your 8N coming? You should see mine!! in reply to Levi (WA), 07-16-2002 14:51:46
Not sure? If it starts to leak then it is. You can clean and re/seal it if is, just all kinds of anti-freeze will go on your nice new clean floor in your shop! Be sure to replace the nuts with brass ones if they arn't allready that way they tend not to rust to the studs. Mark H.
Levi (WA)
07-16-2002 16:33:25
 Re: Re: Re: Levi how is your 8N coming? You should see mine!! in reply to Willy-N, 07-16-2002 16:15:37
Oh sure...not as worried about the floor as I am Jake having a drink...yeah I already ordered the nuts and washers from Don along with MORE SUPPLIES...LOL...
