...Air filter
Chuck...Warrent
07-14-2002 18:41:07
...Hello...I have an early 8N...My air filter is not like shown in the manual...insteaed of the spring type clamps on each side, its a key type band holding the bottom oil sump on...I replaced the oil but did not see anyway of getting into the top half of the canister, no wing-nut on the top to open?????...Whats up?????....Chuck
Jeff Hoo
07-14-2002 20:17:58
 Re: ...Air filter in reply to Chuck...Warrenton Va, 07-14-2002 18:41:07
Thanks for posting this, Chuck... I had wondered the same thing. So I just did the same thing...replaced the oil and cleaned out the bottom of the cup and left better enough alone.
Looks like there's some detents that could be pressed in to get that retainer out, but I can't tell.
Dell (WA)
07-14-2002 19:17:10
Chuck..... ....thats all you gotta do. replace the oil in the bottom half. The carb sucks up some of the oil into the wire wool screening and that captures the really fine dirt which then drains backdown into the oilcup when you turn your engine off..... ...Dell
