Lift arms will not lower
Jay
07-13-2002 22:03:55
Help! 1952 8N lift arms will not lower. Was bushogging and went to lower deck but it is stuck in raised position. Any ideas?
Thanks
Hunter
07-14-2002 07:23:43
 Re: Lift arms will not lower in reply to Jay, 07-13-2002 22:03:55
Sounds like the exhaust valve is stuck down in the hydraulic pump. take off the right side inspection cover and stick your hand down in the bottom of the tractor, you'll feel 2 valves it'll be the 1 on the right i think. just work it back and forth a few times. I used some wd40 on mine a few years back to loosen some light rust. You'll probably want to drain the lift and rear and tranny first. remember 3 plugs under the rear portion of the tractor.
