Order Ford 8N Parts Online
8N Fan Belt Make and Model
Jeff
11-27-2000 14:45:11
Can anyone give me a make and model number for a 8N 1952 fan belt with the side distributor? Mine is unreadable and the auto parts stores have not been able to help me without a number. Thank you.
Carl/Pa
11-28-2000 04:36:54
 Re: 8N Fan Belt Make and Model in reply to Jeff, 11-27-2000 14:45:11
If you have the old belt, broken or not take it in to the store and measure it on a belt gauge. If you measure it with a string around the pulleys, be forwarned the string fits down in the pulley further which shortens the total circumference by a lot after going around 3. Also it is important to get the proper width and depth of the belt so it rides correctly in the pulleys. Can't believe the parts store can't fix you up with one.
Jim.UT
11-27-2000 18:42:14
Find another parts store. My parts store has a belt sizer. You put the old belt on the sizer and stretch it out as far as you can, then read the size on the scale. If your old belt is broken, you could accomplish the same thing by tying a piece of rope around the pulleys and tying the ends together to retain the loop dimension, then have the parts guy put your rope loop on his belt sizer.
