A warning for newbies like myself
Mike Stromberg
07-10-2002 08:32:31
I've been reading the archives regarding the hydraulics and I've noticed a lot of talk about checking the oil for the presence of water (milky appearance). Thought I'd mention that the oil on my tractor's dipstick was always perfectly clear, but when it sprang a leak (recent thread) the fluid was like pink paint (color and consistancy).
When I opened the drain plug I got a couple of cups of water before the remaining oil started draining. The hitch worked fine in spite of this, but I didn't have a chance to try it last winter either.
Tyler (MD)
07-10-2002 15:45:47
 Re: a warning for newbies like myself in reply to Mike Stromberg, 07-10-2002 08:32:31
Most people think that water accumulates inside the housing through your cracked/torn/non-existent shifter boot. I know for a fact that all the the water I get in my 9N's housing is from condensation. dave#1 drilled and tapped his main tranny plug for a 1/4" pipe plug. So when he needs to drain some water out of his tranny, he just loosens the pipe plug, drains the water until oil starts to appear and tightens the plug.
FWIW,
Tyman
Mike Stromberg
07-10-2002 19:02:23
 Re: Re: a warning for newbies like myself in reply to Tyler (MD), 07-10-2002 15:45:47
Interesting Idea. In my case it's probably the torn-up shifter boot that barely is remaining on the stick. The funny thing is that the former owner (I got this with a 3 acre farm I bought from him) told me that the tractor got more TLC than his cars.
Dell (WA)
07-10-2002 19:21:08
 Re: Re: Re: a warning for newbies like myself in reply to Mike Stromberg, 07-10-2002 19:02:23
Mike..... ...new shifter boots $3 cheap. Boil'em in hot water to make'm softie to fit over the bulges..... .....Dell
OKcity8N
07-10-2002 09:54:38
I changed my hydraulic fluid last week. The water in it had completely emulsified with the oil. The lift barely worked at all. The color will vary depending upon the color of your oil. Mine was pale yellow. As MH said, I was lucky that it didn't freeze and bust the pump. However, in OKcity, it rarely freezes that hard. Since I keep the N in the shed, it is unlikey that the water got there recently. It must have been there from the previous owner. It is a messy job to change, but with experience, it gets easier and cleaner.
Mark Hendershot
07-10-2002 08:38:04
The water can settle on the bottom and not get picked up by the pump all the time. If you are lucky it will freeze in the bottom and not in the pump and crack it during cold winters. It gets mixed with the oil while useing it a lot then will settle out some after it sits for a while. I have found chunks of ice in the bottom when taking pumps out during the winter! Mark H.
Dave OH
07-10-2002 23:51:32
 Re: Re: a warning for newbies like myself in reply to Mark Hendershot, 07-10-2002 08:38:04
OK Mark, I get it.
You want your wife to buy you a heater for the barn, right?
Dave OH
Mark Hendershot
07-11-2002 07:47:46
 Re: Re: Re: a warning for newbies like myself in reply to Dave OH, 07-10-2002 23:51:32
Your right but I got these portable propane heaters that you can aim at you along with some real heavey jackets and such. The new barn is just to big to heat. I don't like to be cold when I am just standing there. Mark H.
