Re: Alternator Wiring to meter
yes . . . Dell
07-07-2002 06:41:23
Buddy..... ...connect your 2-terminal ammeter thusly..... .battery wire from alternator to one of the terminals of your ammeter. THEN from the other ammeter terminal connect to your BATTERY.
If meter doesn't show charge, swap wires around. Convention sez: ammeter PLUS means you are charging your battery, That is why the ammeter 0 is in the center so you can see plus (charge) and minus (discharge)..... ..Dell
bg
07-07-2002 09:03:28
 Re: Re: Alternator Wiring to meter in reply to yes . . . Dell (WA), 07-07-2002 06:41:23
I was just wondering... wouldn't it be more appropriate to have a voltmeter, rather than an ammeter, in an alternator system?
duey in MN
07-07-2002 12:25:33
 Re: Re: Re: Alternator Wiring to meter in reply to bg, 07-07-2002 09:03:28
Actually you are quite correct for any system except for the older three brush generators. On a regulated system, if the volts are correct, the amperage takes care of itself. And without the right voltage, the amperage is not meaningful.
There was little automation on the 3 brush generator, if you were doing field work all day, you would set the generator for a lesser charge, if it was short trips back and forth to the woods, set it to charge 8 or 10 amps. It was a 'guesstimation' of what the operator thought his battery needed... hence the decal on the battery cover that urged you to CHECK BATTERY WATER DAILY.
A "12 volt" system should, as mentioned many times in this forum, show 14.25 Volts DC under normal operating conditions, half that for "6 volt" and double for "24 volt".
DavidO
07-07-2002 12:04:47
In my opinion, it is better to have an amp meter than a volt meter on the tractor. If you do use a voltmeter, it would be a DC voltmeter which gives you an indication that your voltage regulator is working and that your alternator is functioning to some extent, but not how well it is functioning. The amp meter also gives a better indication of the state of charge on the battery.
Tim
07-07-2002 11:30:58
Would that be an AC or DC voltmeter?
dave#1
07-07-2002 10:48:16
This is hear say, I really don't know. A guy once told me that an amp meter is better to have than a volt meter, he said your chargeing system could be putting out 13+ volts at a 1/2 an amp which ain't enough for chargeing, that's why you should use a amp meter. Sounds good on paper? LOL
Dell or Claus would know this far better than I.
later"belch"dave
Mountainman
07-07-2002 10:18:56
Why??
I've used ampmeters in many alt equiped vehicles.
What would be gained by use of a voltmeter?
Mountainman...CA
Dell (WA)
07-07-2002 23:53:00
 Re: Re: Re: Re: Alternator Wiring to meter in reply to Mountainman, 07-07-2002 10:18:56
Would you believe most ammeters today are really voltmeters with internal shunt voltage dropping resistor and the voltmeter measures the voltage drop and displays this voltage drop as AMPS by magic of different meter face..... ...Dell
Mountainman
07-08-2002 00:16:38
 Re: Re: Re: Re: Re: Alternator Wiring to meter in reply to Dell (WA), 07-07-2002 23:53:00
Dell,
Is that true for SW amp meters made in the seventies? I believe they made a voltmeter also.
But the real question is - Which one is most useful?
Mountainman...CA
Dell (WA)
07-08-2002 06:37:53
 Re: Re: Re: Re: Re: Re: Alternator Wiring to meter in reply to Mountainman, 07-08-2002 00:16:38
While I'm not 100% confident about Stewart Warner ammeters being a DeArsonval voltmeter with a calibrated voltage dropping resistance, (shunt) The technique works well, calibrates well, and is cheap. And has been in use for as long as I can remember and I am 64.
Which is why I get giddy about the N's loop sensing ammeter. It really is a better ammeter.
As to which is better to monitor battery condition? An expanded scale voltmeter is generally considered better. Expanded scale voltmeters are brought to you courtsey of zener diode technology. Ammeters are probably a better measurement of generator/alternator output which is really related to the internal battery cell plate resistance.
Ohm's Law Rules..... ...Dell
duey in MN
07-08-2002 12:00:50
 Re: Re: Re: Re: Re: Re: Re: Alternator Wiring to meter in reply to Dell (WA), 07-08-2002 06:37:53
In the end, the answer to which is better is in the 'eye of the beholder'. The operators ability to understand and interpret what he sees on either ammeter or voltmeter is the key. To some folks, neither guage adds understanding, to others, either one is fully useful. How's YOUR knowledge? E = I x R, Mr. Georg Simon Ohm (1787-1854) showed us how.
I didn't know . . . Dell (WA)
07-08-2002 12:47:33
 Re: Re: Re: Re: Re: Re: Re: Re: Alternator Wiring to meter in reply to duey in MN, 07-08-2002 12:00:50
I didn't know Ohm had a first name.....Dell (grin)
duey
07-08-2002 12:57:57
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Alternator Wiring to meter in reply to I didn't know . . . Dell (WA), 07-08-2002 12:47:33
It doesn't really matter to him anymore!!! He's famous, most of don't get a law named after us... tho we may be called OUT-laws!!!:-)
I'd like a 'law' named after me... Duey's Firewood Law: Never Split Wood Larger Than The Wife Can Handle!
