850 Charging
George
07-03-2002 09:32:22
I have recently replaced the entire electrical system on my 850: New wiring harness, rebuilt generator, new regulator and even a new terminal block and amp meter (all 6 volts). The system seems to work fine, it charges at 10 amps and stays there. Should this charging rate go toward 0 amps as battery is fully charged?
Claus
07-03-2002 10:37:45
 Re: 850 Charging in reply to George, 07-03-2002 09:32:22
You would have to measure the battery voltage to determine the problem. Most regulators will trickle charge once 7.5 or so volts is reached. You could have a faulty or wrong type of regulator as well as a wiring difucalty. For troubleshooting see the link below. Although it is for an 8N, this should work for you as well.
Happy Motoring
Claus
Jon in Mass
07-03-2002 10:20:40
The amps should go to zero once the battery is charged. Could be a bad regulator. For 8N's the FO-4 has procedures for checking the regulator, perhaps there is an equivalent for the 850.
I would also double check the wiring and trace everything out to make sure it matches the wiring diagram.
Jon
